Question about Whirlpool Washing Machines
What is the cost to replace a seal in my washer's transmission
There is grease and oil on the floor under my washing machine
    Problem Solver:
  • 11 Answers
How old is it and would you rather have a different unit. Usually labor and the few special tools needed to perform that task is not cost effective. Be cautious for the springs and preloaded units can let loose and HURT you. Plus why did the seal go out? If there is a bur or a bearing that needs replacing also? Check out the costs. Thats two good reasons to replace than fix. Otherwise if you can find a unit for parts that might work out. Remember this is becomimg a throw away society.
Posted on Oct 30, 2012
SolutionGuy
  • 331 Answers
SOURCE: Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Posted on Sep 01, 2007
  • 185 Answers
SOURCE: Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Posted on Mar 26, 2008
SOURCE: Oil on floor under washer
Thank tou very much you were of great help.
Posted on Mar 27, 2008
  • 6 Answers
SOURCE: Found oil and grease under washing machine. Makes loud noise when on spin cycle.
The oil and grease is probably from the transmission and yes you might be able to replace it. Get your make andmodel number and go to www.repairclinic.com. It is a very good site for finding pictures and parts of appliances. The parts are as cheap as you will find them. If the oil/grease is from the transmission, it will eventually fail. Fix it now or fix it later. Your choice.
Posted on May 30, 2009
barkencoa
  • 3463 Answers
SOURCE: oil marks on my clothes after washing
It could be an indication that the main bearings are failing, or it could be an effect known as grease balling.
This is caused by washing at too low a temperature, or not using enough powder, or using the wrong type of powder.
If it is the bearings, then I would expect it to be getting noisy, particularly on the spin cycle.
Hope this helps.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "great help thanks very much. this could save a lot of money and work."
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
Apr 28, 2012 | Hoover Washing Machines
Grease spot found on the floor from the right side
There is a bearing seal that does tend to leak. Feel free to ask any other questions. I do recommend copy and pasting this link in your internet address bar under a new tab for more great repair info:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 13, 2009 | Maytag LAT3600A Top Load Washer
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
Grease oil ring around tub and it smells like oil?
The only place there is oil in a washer is inside the transmission. If you have oil in the tub (and it didn't come from the clothes you put in) you have a bad transmission seal. It is generally cost prohivitive to replace the transmission. It's time to get a new washer. Look into the front load machines which use much less water and spin out twice as fast as top loaders. Some even have direct drive, which means no belt, transmission, or clutch.
Jul 19, 2009 | Washing Machines
My washer has had streaks of grease coming from under the agitator. It is getting on my clothes and I cannot remove it. I took the agitator off and the inside of it is coated with this grease (black,...
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Jul 13, 2009 | GE WPRB8050D Top Load Washer
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Oil spill under washing machine
Sorry, this could be bad. The transmission might have blown a seal. It's a big job to fix, if this is the problem. It might be time to consider replacing the machine.
Premmy
Oct 21, 2008 | Washing Machines
Mar 22, 2008 | GE WNSE5260D Top Load Washer
I have an oil leak on a stacked washer and dryer
oil leakin on floor is a result of a bad transmission seal, yoiuneed to replace teh tranny and clutch assy,(generally covered for extended period of time through the manufacture(check you owners manual for possible coverage
Dec 10, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
