Km3050 kyocera printing out black line at top of document
jaylex
  • 417 Answers
SOURCE: printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Posted on Dec 31, 2007
SOURCE: black line running through document
I called Epson Support...it's free.
No come on, you ask the question and they return an answer, they don't ask you to join a premium plan.
Have a nice day.
Posted on Nov 20, 2008
SOURCE: black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Posted on Dec 04, 2008
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
Wiired
  • 122 Answers
SOURCE: printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Posted on Jun 22, 2009
My system is displaying programme loading without geting ready, on km 3050
Try updating the firmware, if it does not work you need to replace the panel. but most of the time firmware fix this issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 04, 2016 | Kyocera Mita KM3050 Black Toner Cartridge...
How do I get rid of the black vertical lines for the Kyocera FS1128mp?
make a copy from the document feeder and see if the lines are there. then copy from the platen glass and see if the lines are there. then print to it and see if the lines are there. if the lines ONLY occur when feeding through the document feeder then check the slit glass VERY carefully for debris like gel pen ink and whiteout or other stuff. even one little speck on the thin slitglass will appear as a line on a copy through the adf. if it happens on ALL tests. then it could be a scored drum, bad dv unit, secondary transfer, or fuser.
Sep 30, 2014 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Kyocera km3050 error cfb33
This code means that the operation panel is not correctly communicating with the main board.Try turning the machine off/on.
It may require a firmware update in which case you will need to book a service call with an authorised Kyocera Service agent.
Dec 30, 2013 | Office Equipment & Supplies
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
Black lines print on black and white printing
Sounds as if the drum needs to be replaced if it does this on copies and prints.
If it just happens on copy when using the document feeder then try cleaning the narrow piece of glass that is located just to the left of the large piece of glass.
Jan 09, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
My Kyocera Copystar CS-2114 Copier is printing a one inch black line of the left side of the paper
have a look at the scanner glass especially the thin strip glass this is the glass that is used when passing paper through the document feeder. if you do a copy from the main glass or print to it and no line apears there is probably dirt or tipex or a ink mark on the surfac, the other thing to look at os the drum charge unit as htese can sometimes fail to connesect correctly at the back and not sit tight in the slot this means the drum isnt charged on the edge.. good luck
Nov 17, 2009 | Kyocera Copystar CS-1620 Black and White...
70 people viewed this question
k24674
jasbo
jasbo
