Question about Altec Lansing VS3251 Speaker
How to hook up Altec Lansing VS3251 to tv and dvd player
I have a Samsung 52 LCD tv and blue ray player and do not know what connections I need to hook up the Altec Lansing VS3251 to the tv and disc player
  • no_pain22 Jan 04, 2009
    the audio and video input are not in order
2 Suggested Answers
SOURCE: Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Posted on Apr 16, 2009
SOURCE: The remote of my Altec
Did you get a solution of this problem? I am also facing the problem.
Posted on Aug 21, 2011
The remote of my Altec Lansing vs3251 doesn't work anymore? Why? How can i fix it? :(
Aug 11, 2011 | Altec Lansing VS3251 Speaker
Can I connect this to my tv? If so how-can't figure out how.
Sure, if your TV has some kind of audio outputs (and volume controls) for the "audio 5.1 inputs" you see in this picture.
http://rosario-cavite.olx.com.ph/altec-lansing-vs3251-5-1-speaker-rush-3-8k-19-days-old-iid-24919817#pics
You COULD adapt the probably-present stereo audio from your TV for use with the front channels . Stereo.
May 12, 2011 | Altec Lansing VS3251 Speaker
How to connect 5.1 home theatre to sony bravia lcd tv
how to connect philips home theatre dsp 2500 to sony bravia
Jun 07, 2010 | Altec Lansing VS3251 Speaker
Altec Lansing VS3251 rear left channel not working
Sounds like you "blew" the left channel. Make sure your connections are good, and all positives and negatives hooked up the way they are meant to be. If it still does not work, take it to be repaired. Call around first, with the AND serial number. Get repair estimates, ask about the "bench charge"
Apr 11, 2010 | Altec Lansing VS3251 Speaker
I have connected my philips 5.1 channel dvd player properly with Altec Lancing VS3251 speaker 5.1.There is audio output from the front speakers but there is no audio output from the rear left/right and...
to get 5.1 you need to have an optical/co-axal/hdmi input in to the speakers to get 5.1 and then the dvd player must have one of them as an out put
hope that helped
Jun 18, 2009 | Altec Lansing VS3251 Speaker
Apr 14, 2009 | Altec Lansing VS3251 Speaker
I am not sure how to connect altec lansing vs3251 5.1 with my tv
U can connect it by a Y connector. Its a 3.5mm stereo jack on one end and the other end splits into two RCA sockts. So u can use these RCA sockets to connect to feed the audio output from the TV. thats all.
Apr 10, 2009 | Audiovox Audio Players & Recorders
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec Lansing VS3251 Speaker Logo
536 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
