Question about Ovens
Fulgor 300 series double oven top oven works fine, bottom oven locked code reads f4. What can I do?
  • 3 Answers
This is not a solution but was wondering how you like the oven. Did u get it fixed. I am looking at the dovb33041ass model and cannot find any reviews. How is it a cooking, baking, etc?
Thanks
Posted on Mar 09, 2013
    Top Expert:
  • Ovens Master
  • 76,649 Answers
F4 means a problem has occurred with the oven door latch mechanism. Try unplugging the power to the oven and then wait 1 minute and turn back on, this may clear the problem, if not you need to call a qualified service technician for Fulgor products
Posted on Oct 30, 2012
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
SOURCE: hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Posted on Nov 23, 2008
barkencoa
  • 3463 Answers
SOURCE: just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Maytag double oven-top cleans itself-bottom reads unavaiable?
Either BOTH cannot clean at the same time b/c they heat to 700deg and use alot of power, OR the 'Door secure' signal from the bottom oven is not getting to the controller. I suspect if that is the case, the switch is on the inside of the door, activated by the LOCK lever moving into locked position. It may be a beny switchlever, mis-adjusted LOCK lever or solenoid or disconnected wire.
If you leave the TOP open and force a clean, does the bottom lock and do nothing? (My other theory)
Apr 08, 2009 | Maytag CWE5800A Electric Double Oven
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
F4
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Ovens Logo
180 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
