Question about SuperMicro Computers & Internet
Hardddrive blinking red leds
    Champion:
  • 261 Answers
This is usually a bad hard drive.
Posted on Jul 03, 2015
Green led in ON but red led in blinking,after so many blinks of red led the both lights ,red and green,gone off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 15, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Same Problem
Hello, it was:
■ Charging LEDCharging LED
 Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Computers & Internet Logo
89 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
