Hard disk failure
I have a gateway laptop and a window pops up again n again reading backup files and hard disk failure i dont know what to do
    Scholar:
  • 107 Answers
What exactly does the error say?
The safest thing to do is to stop powering up the hard drive. Get a new hard drive and adapter cable to pull the data off the old hard drive (secondary) and onto the new hard drive (primary) after the new hard drive has been formatted.
If you don't feel you can safely do that, you may want to seek the assistance of someone who can or a company that provides hard drive recovery services.
A hard disk failure error typically indicates the hard drive has (or is about to) fail and become useless.
Posted on Jan 03, 2009
Gateway netbook Kav60 says it cant boot, to insert disc. there is no disc drive.
try ctrl and f2 when starting your notebook if it goes to bios go to restore defaults ,save changes and exit . restart again
Jun 04, 2016 | Gateway Computers & Internet
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
My Gateway file c0000218 registry failure the registry cannot load the hive /SystemRoot/System/32/Config/System or its log or alternate is. It is corrupt, absent or, not writable.
it sounds like you have a bad sector on the part of the hard drive containing this file. you need to let chkdsk complete the scan as it may be able to recover the corrupt file and isolate the bad sector so its not used again.
if this works backup the system as your hard drive may be failing.
Mar 09, 2012 | Gateway MT6821 Notebook
Gateway nv7915u error message i'm getting is pxe-e61 media test failure check cable pxe-m0f exiting broadcom pxe rom no bootable device--insert boot disk and press any key but when i do that nothing...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 04, 2011 | Gateway NV7915u Notebook
I am getting a disk read error upon start up. How do I fix this?
Your computer cannot read your copy of Windows from your 'C:' disk-drive.
You need to purchase a replacement disk-drive, and re-install Windows onto the new disk-drive.
I hope that you have a good backup of all your files!
Mar 30, 2011 | Gateway NV7915u Notebook
Hp invent with windows xp pro after restoring to an earlier date says windows cannot start driver corruppted?Did system Diagnostics hard disk test failed test 2 (Comprehensive)...Error: Read Failure
Restoring to an eariler date cannot fix this problem.
If the hard disk diagnostics failed, this could indicate the hard drive is about to fail. The hard disk platter/s most likely has some bad clusters and if any files are located on these bad clusters then you would get a read failure. The number of bad clusters will increase and cause further problems.
Run chkdsk to lock out these bad clusters but this is a temperoary solution and the computer may not be able to relocate the data from the bad sectors to a good sectors.
The fix is to backup your data as soon as possible, then replace the hard drive with a new hard drive and re-install Windows and the Compaq's device drivers.
Jul 22, 2010 | HP Compaq 6735s Notebook
My gateway laptop 4540gz cant find opp system
Operating system is the main program of the computer. It can b easily detected by your computer in boot up. So if the computer doesn't detect it, this are the steps you can try :
  1. First try to run system restore if you have one.
  2. If you don't have system restore disk, or back up disk, you can remove your hardisk from your laptop and try to connect it to other computer as an external hard drive. in that, you can copy important files and back up it in other computer if it is not also deleted.
  3. Then if you have back up your file or not, you must format your hard disk. return your hard disk to your laptop and format it.
If you don't know how to format just ask again here.
Feb 28, 2010 | Gateway 4540GZ Notebook
" disk read error press ctrl+alt+del+ to restart" on boot up
This error message means you have a hard disk failure, especially when you try to reinstall windows and it cannot detect a hard disk.
Replace the hard disk..
Jan 28, 2009 | Gateway M350 Notebook
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
A disk read error
The "clicking" and "disk read error" indicates a hard drive failure.  When the PC boots it can no longer read some files from or the entire HD.  The corrective measure would be to replace the HD and install your OS and programs. Alternately, you may try and reformat then re-install but then you would be operating with an unpredictable storage media and perhaps prolonging the inevitable.
If your reason for Safe Mode is to be able to access your files for purposes of backup, the constant trying/on-off just might worsen the condition of the HD. You can still try recovering by installing the HD in question inside a 2.5 enclosure to USB and install it as a removable device in a 2nd PC where you can try recover files.
Should you install a new HD and install the OS in your Gateway, you actually can use that to try and recover from the old HD. Recovery is 50/50.
Good luck and kind regards.
Oct 25, 2007 | Gateway M675 Laptop
Computers & Internet Logo
467 people viewed this question
David Payne
David Payne
