Question about Dishwashers
Kitchenaid dishwasher not filling with water
Washer has power and will run if I put water into the bottom of the dishwasher. But no water is being pumped into the dishwasher. We have a lot of mineral/ calcium deposit buildup in our machine. My husband & I took off the filter and cleaned out all of the visible calcium deposits around the pump. I have also run a cycle by adding water to the bottom of the dishwasher and used one bottle of "Dishwasher Magic".
Skill Will
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
ginko
  • 19396 Answers
SOURCE: need to clean lime and calcium deposit from bottom
The cheapest way is using homemade vinegar and lemon solution. If the deposit is big use a commercial cleaner. See the links below:
cleaning calcium deposits from dishwasher
How do I clean my dishwasher
How can we prevent dishwasher detergent residue?
Buy Dishwasher magic Cleaning Supplies
Removing lime from your dishwasher
Lime Away To Clean A Hot Water Heater
Automatic Dishwasher Cleaning Tips
How to Clean Your Dishwasher
Posted on Apr 13, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE Nautilus dishwasher keeps PUMPING water "out" of the machine during the entire wash cycle. I have removed all covers in the bottom of the unit to see if anything is stock. Used vinegar and CLR
If this convert-able dishwasher is permanently installed, you will have to take off the lower access panel to get to the pump area. If it is still in a portable configuration, it may be easier to lay the dishwasher on it's back or side to do this. Now, examine the pump / motor assembly. There is not a separate water pump on this model. There is a diverter pump out solenoid which get's pulled down to direct the water out the drain hose for pump out, which is suppose to spring back out of the way to allow water to go up to the spray arms for washing. I suspect that the solenoid got to hot and the plunger will no longer slide in the solenoid. If this is the case, you can replace it with a WD21X802. If the arm and plunger move freely, check the spring, or for obstructions in the pump housing, or possibly the diverter arm in the pump housing has come loose from the shaft. The solenoid is the most likely.
Posted on Apr 30, 2009
  • 82 Answers
SOURCE: Mineral deposits on heating element of dishwasher
There is a chemical you can buy that is a dishwasher cleaner that should do it. Wal-Mart or an appliance store should have it. If it is bad, you may have to do it several times. Ultimately you may need a new element if it is real bad.
Posted on Jul 01, 2009
  • 10 Answers
SOURCE: how do I dissolve dishwasher calcium deposits w/o causing leaks
White vinnegar
Posted on Feb 24, 2010
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
Have a kitchenaid double drawer dishwasher. While running the bottom drawer the top drawer fills up with water. Had the filler valve on the garbage disposal changed. Issue still continues. Any suggestions
Mine does the same thing! (Same model) I've finally discovered that if I start the bottom drawer first and the top drawer just after that doesn't happen as much. Also, if I run the garbage disposal (and water obviously) while it's starting (I will try to do my hand washing while the dishwasher is getting going) that seems to keep this from happening as well. I've given up running just one drawer, which totally defeats the purpose of buying the 2 drawer dishwasher. But it does keep me from having to bail the bottom drawer :-( I'd like a better solution to this too!
Sep 10, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Bottom of dw full of water and leaking past door seal
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Sep 09, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Kitchenaid KUD101FLSS3 Won't Drain
did you take the knock-out from the garbage disposal. It is located in the line where the drainhose is connected.
Mar 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water in bottom of dishwasher after cycle
as ur dishwascher is brand new why not call the service and get the, solve the problem.....or u can go in touch with the store u bought the dishwasher and ask them to fix it....i think it will be under warranty being new
Mar 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
No water flow through dishwasher
No you need to clean out the spray nozzles with an old toothbrush etc both top and bottom and also clean out the debris filter below or at the heating element at the bottom of the washer. Then run a bottle of dryright etc. to help clean up the buildup in the machine. Then do this once or twice a year from now on and that washer should work great. Hope this helps.
Jan 18, 2009 | KitchenAid 24 in. KUDI02FRSS Stainless...
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
