Question about Dacor DMT2420SS Microwave Oven
LCD panel dimly lit, microwave works fine.
We had apower outage in our area and when it was restored the LCD panel on the microwave barely is visible. It looks like it is working at 30 Hz when it should be running at 60 Hz. If you push the screen where the buttons should be, the oven will will work fine. Any suggestions? This is a Dacor model DMT2420S, about four years old.
  • Dacor Master
  • 9,098 Answers
You have two options for this model:
We can repair your control unit for $39.95 in about a week or you can order a modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
Frigidaire FPBM189KF microwave digital display is barely visible
Hi Gary, thank you for your post! Often if the display LED's are dimmed, it is because the issue may be related to a communication error with Main Control board or a potential wiring failure. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Aug 01, 2013 | Frigidaire FPBM189KF
Control Panel illumination has dimmed
You can try a hard reset. Unplug the oven for about 1-2 minutes, plug it back in, then try it again.
Otherwise, you may have a bad connection on the controller assembly.
Those can be repaired, usually economically.
Without your full model number from the tag, we can't give you a more detailed response.
Jan 30, 2013 | Microwave Ovens
It's a GE microwave..model PVM1870SM1SS...mfg. 10/07..panel light is VERY dim...cannot read unless you shade all light with hand otherwise works fine...tried re-boot twice no affect.All other GE...
It sounds like you need a new display, if it is neon or a new back light if it is an LCD.
Contact the manufactureres web site for details of a dealer in your area for spare parts.
Hope this helps.
Nov 16, 2010 | GE Advantium 120 Convection/Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Sharp R-1480 failed after a power outage
It's most likely the low voltage transformer that's part of the circuit board or a blown trace on the board. The HV transformer would only burn and smell if the unit was in a cook cycle.
The complete board assembly is only around $80. If you're really handy, you can order just the little transformer, but you'd have to remove (unsolder) the old one and install (resolder) the new one on. The circuit board is one assembly and it takes all of 30 minutes or less to replace from start to finish.
Check with Martin Microwave Inc. @ 1-877-894-0035 to order or to inquire.
Oct 30, 2008 | Sharp R-1480 Microwave Oven
Display is extremely dim to where you almost can't read it anymore
take down the display and clean the contacts if that does not work replace it.good luck.
Apr 27, 2007 | Sharp R-360E Microwave Oven
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
338 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
