Question about Candy GOY105 Front Load Washer
My candy grand q washing machine its like it is stuck between cycles
I started the machine and the power went out after it came back on the red lights were on but it wouldnt switch back on
  • 135 Answers
SOURCE: Hi, I have a Candy
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Posted on Dec 02, 2008
  • 197 Answers
SOURCE: My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Posted on Sep 29, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
SOURCE: I am using a candy cty 105 smart. The machine
i had this problem to.. my solution for this was the wire of pump. wire was just unpluged i just re entered the wire end all was back to normal.. :P
Posted on Feb 28, 2010
caroldon
  • 17130 Answers
SOURCE: smoke has started to come
This is something which you need to probe with precaution as the possibility can be various.
It can be the motor, the capacitor to the motor, the valve, pump or the control board.
in all these cases the observation and inference will be related to your view.
MAke sure that the power is disconnected before you probe into , smelling for the burnt item.
Posted on Feb 18, 2011
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
Aug 12, 2015 | Candy Washing Machines
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Grand o 282
Seems that you need to check if the door switch is faulty or there is fault or loose connection on the switch. Remove and check for the switch action, replace if faulty.
Nov 21, 2013 | Candy Washing Machines
Dec 23, 2009 | Candy Washing Machines
Machine has power but not moving through cycle
Hi there. I have a candy cwb110 and the bearing on the motor went. I replaced this put it all back together and now when you set it to wash it wil only spin for 30secs and then it will end it's cycle and do no more!? wil drain it's water fine on that mode just wont run it's wash cycle. motor sounds healthy when it is spining.
Is there a reset on the computer side of things or something i may have done wrong?
Cheers
Wyn
Mar 10, 2008 | Candy AQ130 Front Load Washer
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy GOY105 Front Load Washer Logo
65 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
