Question about Iwill DVD266u-RN Motherboard
Dvd266 will not power up
Novice builder// I am working on a project with my daughter to build a PC. I have it all together but it will not power up. All components are new and I have even swapped out the power supply
  • Desktopsbyduck-Computers
    Ok i am here to help.first off what motherboard do you have.and any hardware list is helpfull.RICHARDM69
  • 107 Answers
Make sure there are only the screw mounts you need in the case cause one at the wrong place can cause grounding and shorting
Posted on Jan 03, 2009
Is it safe to connect a main support beam 26ft long in 3 peices with 3.6 connection at each end put together with cariage bolts, ?
No, because carriage bolts will rust through in time. The ends are the worst for rusting. This is why I told you to contact your local authority building officer, to check on building code regulations.
There was a nice bungalow near where I live used as an insurance business. They decided the basement although a little low on headroom would be good for storage. Someone had the bright idea to lower the floor in the basement. They got in a firm of cowboy builders who really didn't know much about building codes. Part way through the upstairs collapsed into the basement at an angle of 30 degrees. The two idiots digging the floor out, got out unscathed, but a bit shaken. Police and fire officers arrived, and the next day the building inspector. The building was condemned as a totally unsafe structure. It had to demolished professionally piece by piece and also remove all the items that were inside the upper floors. All that took about 6 months and then another 18 months to rebuild the house properly. The final part of the cautionary tale was that the although the builders were insured, they wouldn't pay out because the work wasn't done to code. The building was a State Farm office so that helped.
Feb 17, 2018 | Cars & Trucks
I need help upgrading my Dell E93839 SCMO215 motherboard
support.dell.com
Look up you motherboard ,find out the maxium speed CPU that the board can handle. You may have a problem with the power supply beign too small. If runign Xp your Ram is already maxed out. Good luck.
Aug 26, 2014 | Computers & Internet
My daughter needs to build San Juan Bautista Mission
milk-quart-1/2pint cartons ,egg.cartons and empty tube from paper towels spray paint
Feb 22, 2010 | RTO M-D Building Products Carpentry &...
My daughter selected the systems menu and selected Format She lost all her music and videos. Is there a way to retrieve them?
There is a way but it will be difficult. There is a program for free on the net called "Bart's PE Builder", (Google for Bart's PE Builder). You have to download and read as much info as you can on how to use it, and build your PE or the CD rom you will need. You make a Boot-able CD with this program and your MP3 player will have to be set in the MSC mode as a Mass Storage device. This way PE builder can see it and you can use the "undelete program" to find your MP# files. Now all this MAY OR MAY NOT WORK. Lots of things depend on you being able to retrieve your files, such as, have you added anything to it since the delete, has the battery gone dead, on and on. BUT, IT DOES WORK I HAVE USED IT. It is to entailed to explain here how to build your CD and how to used the program. It is worth all the reading to get your stuff back. .
Feb 11, 2010 | Audio Players & Recorders
Hi my name mohit manchanda. actually i wanna instal win xp in my [pen drive but after copying files 100% than sytem show fetal error
All that's needed is a bootable USB Flash drive with at least 256 MB of storage capacity and a Windows Setup CD. Using the program Bart PE Builder (Freeware), you can install Windows XP on the flash drive, along with other software as needed (and as available space permits).
Here is the link of Bart PE Builder
http://69.90.47.6/mybootdisks.com/mybootdisks_com/nu2/pebuilder3110a.exe
Here is the procedure
This will help you create your very first BartPE CD. It assumes that you are using Windows XP.
Make sure that your system has about 500MB of free disk space!
Download the latest PE Builder version (self-installing package) and install it.
Start PE Builder (pebuilder.exe). When you start PE Builder for the first time it will ask if you agree with the license agreement.
Now PE Builder will ask to search for windows installation files. If you don't have your windows XP setup/installation files on your system you must insert the original Microsoft Windows XP installation/setup CD at this point.
The files you have at c:\windows are not installation files. They are your already installed files!
Click "yes" to start searching. PE Builder will now search all fixed- and CD-Rom drives for Windows installation files. This will take some time. When more than one valid location is found, a dialog will appear where you can select which location you want to use.
At the main PE Builder dialog, select the "Burn to CD/DVD" option. When you are using an erasable medium, make sure that the "AutoErase RW" option is enabled. The "burn using" option should be set to "StarBurn". Select your CD writer device from the Device list.
Hit the "build" button. PE Builder will now ask you to create a BartPE directory, answer with "yes".
The license for your Microsoft Windows XP product is shown. Read it and agree to it to continue.
PE Builder will now start building BartPE. This will take a few minutes.
You will see a lot of files getting copied and/or decompressed, the ISO image build and the data recorded to your CD/DVD writer.
If the data verify was correct and there where no errors reported you can boot the CD/DVD!
After that set your PC BIOS to boot from USB,then restart.
That's it.
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
I am looking for the manual for the DVD266-r
Here you go
http://www.motherboards.org/mobot/manuals/IWill/DVD266-R/
post again if you have any more to ask.:)
Remember to rate Ty
Jan 09, 2009 | Iwill Computers & Internet
Iwill DVD266u-RN Motherboard Logo
35 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
Willem.
Willem.
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
