Whirlpool AWZ 612 E13 Error code on hot wash
Hi, Have an odd problem with my washer dryer (Whirlpool AWZ612). If running on 30/40 degree programs it works fine, however if run on a higher temperature wash then it has an error towards the end of the wash (but does not go through complete cycle)- Error message E 13 and the door remains locked. am able to get clothes out if turned off at the wall for a while. After some googling I believe this is a door lock error however am confused as to why this only happens on hot wash. Any ideas to fix this?
    New Friend:
This happens to me as well when I use drying. After using the machine, when I want to reuse it I get this error "E13". Somehow I manage to make the machine pass the error...
Though I am able to open the door. Here is how I do it (be careful if there is a lot of water in the machine):
- turn off the machine by switching the program knob to "Off";
- wait a few seconds (5 to 10 seconds or so);
- turn the program knob to any program (e.g. Cotton 30);
- the machine will do several clicking sound;
- one of the clicking sound is actually the door unlocking, at that moment open the door;
- turn the knob to "Off".
Hope that helps.
Posted on Aug 31, 2015
5 Suggested Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
jgwhomeequip
  • 1902 Answers
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
SOURCE: door is locked code F21 wont run or cycle or empty water
Try hitting the stop button twice - we are having the same problem but ours isn't draining
Posted on Jan 13, 2010
  • 182 Answers
SOURCE: I live in an apartment
try to unplug the unit for 5 minutes and see if this helps.
Posted on Dec 17, 2010
Whirlpool awz 8666 all programs working but no hot air
Is this a washer or dryer? If it's a dryer, is it gas or electric? If it's electric then reset the breaker (both) in the box. Need more information
Jan 06, 2014 | Whirlpool Washing Machines
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
The water is cold on the 40 degree wash (programme 4). It gets hot on the 60 and 90 degree washes, so the hot fill valve is working (changed it for a new one). I can't find a service manual for...
Whirlpool AWZ 410 Service Manual
The manual is not redundant. In other words it shows the cold info and not the hot. However if you look at the entire manual it shows both functions and starting on page 10 shows the hot wash sequence of events.
Nov 20, 2017 | Whirlpool AWZ410 Front Load Washer/Dryer
What to do if whirlpool awz 50e washing machine is showing water closed tap indicator although tap is not closed
Providing that the tap is turned fully on and the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Mar 27, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Where to find quick guide of whirlpool AWZ 475
I have moved into an apartment with a whirlpool AWZ475 washing machine with no instructions. Is there somewhere I can get an operators instructions on line ?
Mar 04, 2009 | Whirlpool Washing Machines
Washing Machines Logo
2,597 people viewed this question
Top Washing Machines Experts
