Question about Ricoh Office Equipment & Supplies
I have a problem, the printer ricoh mp5500 appears error code SC 495 what is this? I already cleaned up the end toner sensor, but the error still.
RICOH MP 5500 error code SC495
2 Suggested Answers
newport74
  • 58 Answers
SOURCE: I have the same problem with a Ricoh aficio 700 SC495
check the door contacts and the contacts on the transfer unit these need to be clean also
Posted on Apr 06, 2010
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
Sc 495 ricoh mp 7000
Waste toner auger is clogged and won't turn. Also, the sensor on it could be dirty. Remove the assembly and clean it. It is behind the back panel - it is a small black assembly with a white hose attached to it.
Jun 16, 2014 | Savin Office Equipment & Supplies
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Aficio 270, Sc 392, error code
Good morning,
I need help, my Ricoh Aficio 1022 with this error SC-392 is an error of sensor density toner.
I've only had the unit for another and still the same, and the unit is running on another machine.
Already cleaned the connectors Unit
Please if someone can help me.
E-mail: cybercopy.udi @ hotmail.com
Jul 16, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
How to remove failiure code sc 322 ? copier
This is a laser sync error that given everything you have done is probably caused by toner on the OPTICS. It is time to clean up the lenses, mirrors and detectors. It is not a good idea to use canned air or cleaners to do this as it spreads toner in places you do NOT want it.
Kelly
Mar 11, 2011 | Ricoh Office Equipment & Supplies
Sc 400 error
SC 400 is a dirty toner mark sensor. Clean with alcohol, wiping with dry cloth causes static on sensor and attracts toner.
good luck
Nov 30, 2010 | Ricoh SP C221SF Aficio Printer
Sc 400 code ricoh c221
An sc400 error means the toner mark sensor needs to be cleaned. Cleaning this sensor is easy:
Open the top cover and remove the cyan toner cartridge. You'll see a long black lever with a sort of handle that pokes upward -- slide this lever ONCE to the left, and then it should slide back into place.
Now replace the cyan cartridge and close the cover, and your printer should be fine. (If the error doesn't clear, turn the printer off and back on and it should go away.)
Aug 19, 2010 | Ricoh SP C221SF Aficio Printer
Code 590
Exhaust fusing fan motor error. Used toner collection Motor error. Might have some troubleshooting to do on this one.
Nov 18, 2008 | Ricoh Aficio MP1600SPF Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
183 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
