Question about Canon SELPHY ES2 Printer
Paper jam selphy es2
Paper jam
PA8558
  • 28 Answers
SOURCE: i860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 70 Answers
SOURCE: paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Posted on Mar 27, 2009
RPFinney
  • 385 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Posted on Apr 21, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
I don't have the paper tray. Can I feed photo paper into it by hand?
Yes you can one at a time but you need to have it positioned correctly or the machine will not feed the paper in straight and you will wind up with a paper jam.
Jan 10, 2016 | Canon Selphy CP510 Thermal Photo Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Cannon selphy es2 - how do i remove old cartridge?
you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
Jan 18, 2010 | Canon Office Equipment & Supplies
Paper will not lift. error code dc00
Remove any paper you find jammed. When pulling from the front there will be resistance from the paper feeder. Pull slowly - the paper will rip ..
Video 1 -
then clean the rubbers which picks the paper with the spirit
Jan 03, 2010 | Canon SELPHY DS810 InkJet Photo Printer
I get paper jam notice, remove jam and restart. There is no paper jam,when I try to print only half of picture prints
Make sure there is plenty of room behind the printer, the paper is drawn in the front and sticks all the way out of the back before it starts printing, it will show a jam if it can't get all the way out of the back slot.
Aug 28, 2009 | Canon SELPHY DS810 InkJet Photo Printer
User manual required
Hi there here is the link just click it or copy and paste it to your browser http://www.generalmanual.com/Printers/Canon-SELPHY-ES2-Compact-Photo-Printer.htm
please rate me thanks have a nice day
Jan 03, 2009 | Canon SELPHY ES2 Printer
Selphy 720 !st card pass.card stopped partway by power lead-carelessly placed.no paper jam.But display now permanently shows paper jam symbol- not cleared by off/on. no function from any button. ...
Start first unplugging power for ten minutes, and see if it clears the error.
If it does not inspect the printer for paper or foreign objects, take out cartridge and put it back, see if this helps.
Oct 02, 2008 | Televison & Video
Canon SELPHY ES2 Printer Logo
133 people viewed this question
old marine
old marine
