Question about Refrigerators
No water from fridge, water pressure to fridge connection is OK
This happened before, then magically cleared up
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
IF THIS IS A GE SIDE BY SIDE THE WATER LINE IN THE DOOR IS FREEZING THERE IS A HEATER KIT THAT GOES BEHIND THE DISPLAY ON THE FREEZER DOOR THAT WILL FIX IT
Posted on Nov 02, 2012
We have Samsung RF4287HA fridge. Not making ice. Press test button and nothing happens. Do we need to replace the control module?
1. make sure the water filter isn't clogged
2. are the water lines connected to your fridge pinched
3. Is the ice bin completely full
4. Is your freezer not getting cold enough
5. Is the water pressure too low
6. Is the water valve behind your refrigerator turned off
Nov 12, 2017 | Samsung Refrigerators
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Hi i have a fridgemaster fridge freezer and it was moved from mil house on Wednesday. It now will not freeze although it does get some ice at the back of freezer but then defrosts itself. The fridge will...
Have you made sure that that the water connection to the ice-maker is secure and without leaks or stopped up (kinks) in some way? I would suggest that you unplug it for bout 30 min., then plug it back in. See what happens about after 45 minutes. If it was moved, you want to make sure you have tapped into the main water line. It doesn't just magically happen. Sometimes the simplest things can cause immedite problems.
Jan 18, 2018 | Siemens Bosch Neff Integrated Fridge...
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Water coming out of the center top of the
Your defrost drain hose has become dislodged. This happens a lot when people pressure wash their fridges. Look very carefully for a clear frosted looking hose under the panel and reconnect it.
Mar 09, 2010 | Refrigerators
Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Jun 09, 2009 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Water builds up uner bottom drawers
We had the same problem with our fridge.
Try checking the outlet drain hole (if there is one) on the back wall of the fridge.
If it is blocked - clear it out using something like a cotton bud etc.
The water normally goes out through this hole to a collector tray mounted on the
motor / compressor.
The heat from the motor evaporates the water.
If the hole is blocked - it cannot do this - so check it out.
All the best - Stuart
Jun 05, 2009 | Magic Chef CTB1922 Top Freezer...
GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
May 15, 2008 | Refrigerators
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
