Question about ViewSonic VG900 19" Flat Panel LCD Monitor
VG910s not recognizing DVI input
Hi I have a ViewSonic VG 910s, which I was using connected to a Macbook Pro via DVI. A week ago, a connected them (as usual) an the monitor didn?t respond. It is just black, and if I turn it off and on the ?no signal? sign appears. The monitor is working nicely via the VGA input (which BTW connects to the DVI adaptor of the MAC) with no problem. Any ideas on which could be the problem with the DVI? Thanks
    Genius:
  • 2,985 Answers
Graphics card need setting to DVI out put Check your manual
Posted on May 17, 2007
Recognize macbook connect
You may need to check the settings of your mac book that permits you to output the signal to an external display. Also you may need to purchase a display port adapter (VGA, HDMI or DVI) that is compatible with the input connector on the projector
Dec 18, 2013 | Dell 2300MP Multimedia Projector
I have an Acer X223W monitor. I have been using it with DVI input. I need to switch so that it uses VGA. When I connect the VGA cables, the computer goes into power management mode. I can't get it to...
The VGA section of the Monitor is totally separate circuit than that used by the DVI circuit. Either or will do an automatic switch to what ever circuit communicates via the proper attachment (VG or DVI cable). AS long as the VGA Drivers are up-to-date the operating system should recognize the Video signal. Check the DEVICES and look for Video. Your Monitor should show up if the connection is proper, and if not there, you may have a bad Video Cord.
Jan 16, 2018 | Acer X223W Monitor
Connecting LE26R8 to MacBook Pro
Hi.
LE26R8 its a Samsung LCD TV.
You can Connect a LCD TV to MacBook Pro.
You need a mini dvi to dvi or mini dvi to vga depending on your monitor. You also need a cable to get the sound to the tv from the macbook (from headphone output specifically)
Also Watch this video its a Tutorial to How Connect a LCD TV to MacBook Pro.
The Video:
(do not delete)
Good Luck.
Nov 03, 2009 | Samsung Audio Players & Recorders
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
Won't recognize DVI
You need to set your input of the televison to either 4 or 5
Jun 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
May 22, 2009 | Yamaha RX-V563 Receiver
Conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
Aug 12, 2008 | Sony STR-DG510 Receiver
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
IBM 400M DLP projector
not able to be used with a mac.
Jun 23, 2008 | IBM M400 Multimedia Projector
ViewSonic VG900 19" Flat Panel LCD Monitor Logo
231 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
