Question about Car Audio & Video
My orion 2150sx is smoking when powered
THE AMP HAS A BIG PROBLEM.WHEN POWERED CORRECTLY IT STARTS TO SMOKE AND 1 COMPACITOR IS LOOSE.IS THIS A COMMON PROBLEM AND FIX FOR THE OLD SCHOOL ORION 2150SX?
    Master:
  • 444 Answers
No some one did not have the speakers hooked up properly ,End probably went under the OHM,Rateing for the amp, Or use the wrong OHM SUb on it, OR if they used a Dual voice coil sub,Didn,t have it wired up Properly.
Posted on Oct 31, 2012
The Marv
  • 72 Answers
SOURCE: Smoking Amp/Fuse Blowing
Sounds like you may have a shorted switching Transistor in the switch mode power supply causing a short to ground. If you are technical enough. Remove power remove cover and do a continuity test on the transistors on the heatsink. non of them should read zero resistance between the three legs. in all connection configuration you use to hook up your meter. If one or Two or even all of them do you must replace with proper part.
Posted on Aug 03, 2006
  • 631 Answers
SOURCE: orion 2100 hcca
I have a few photos of the 2100hcca. Where are the burned resistors on the board?
Posted on Nov 05, 2007
SOURCE: jl 1000/1 amp not working w7 like it should
also you can call the jl service they will help you they will charge you like $115 to fix it
Posted on Oct 10, 2008
  • 631 Answers
SOURCE: red protector light
Try this first:
Amp in Protect - Troubleshooting
If nothing there helps, you need to return it to the seller if it's under warranty.
Let me know if you have any other questions.
Posted on Nov 16, 2008
  • 17 Answers
SOURCE: orion hcca 2100 old school
Try this page:
http://www.orioncaraudio.com/Support/Manuals/Amplifiers/HCCA%20Series/Orion%202100HCCA%20Installation%20Manual.pdf
Posted on Dec 09, 2008
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
White smoke came from the exhaust pipe and the car killed in motion. I check all fluid levels were fine, once i started the care again and proceeded the accleration was a bit rough. After a few minute
white smoke mostly is caused by over fueling so what i suggest you do is first of all check if there is no leak on the injectors and if there is none which means your valve sterm seals are damaged.When the head gasket is blown out you may have problems like :-loosing power when driving,over heating,idling problems and oil mixing with water, its not your head gasket.
Oct 21, 2012 | 2009 Ford Focus
Black smoke and 'juddering' when stationary.
YOU HAVE RICH MIXTURE. CHECK FOR YOUR TEMPERATURE SENSOR WHICH I BELIEVE IS NOT SENDING THE CORRECT MESSAGE TOY PCM AND STILL WORKING ON COLD START.
Aug 30, 2012 | Audi A6 Cars & Trucks
The fuses blew but then smoke came out of my orion 2400.If I replace the fuses should it still work??
If you are a lucky person..maybe.. but i highly doubt it. ..Sorry.. Smoke is never a good sign when it comes from within the amplifier. Be aware i am advising according to the info you provide. Have it checked and repaired if required, it is a good amp. (find an authorized technician) dreamsystems
Feb 08, 2011 | Orion HCCA-D2400 Car Audio Amplifier
I have an Orion 2150sx and an Orion xtr2150 will either of these run on a one ohm load ? If not what is the best way to run either of these amps to get the most power out of them. I have two Orion xtr...
EITHER OF THEM WILL WORK AT ONE OHM WITH NO PROBLEM, MAKE SURE YOU MAINTAIN VOLTAGE INTEGRITY, USING EITHER 2 OR 0 GUAGE POWER AND GROUND AND A POWER RATED ALTERNATOR AND BATTERY.
Nov 03, 2010 | Orion 2500D Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Power Acoustic A3000DB mono amp problems
Broken legs on the rectifiers or an intermittently shorted common mode inductor would be the likely suspects. The common-mode inductor is just to the right of the capacitors in the photo. Install a single 15 amp fuse in ONE of the 4 fuse holders (other 3 fuse holders empty) and power up the amp. Twist the inductor to see if the amp draws excessive current (which would blow the fuse) or to see if it sparks.
Oct 31, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Aug 02, 2006 | Legacy LA838 Car Audio Amplifier
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
