Question about pharmacia Science & Laboratory
Pharmacia Lkb Controller Lcc-501 Plus problem
The controller for our FPLC is giving the message 'burn in' in the display and then just slowly counts up from 0:00. the keypad is unresponsive. I have tried disconnecting the controller and rebooting it. No change. This problem occurred after a power failure to the Research Centre. Is there a way to correct this problem?
    New Friend:
We had the same problem with our LCC 501 Plus liquid chromatography controller - after "master restart" by pressing "reset/diagnostics" button on rear panel, the controller indicates "Burn In" message and slowly counts (i.e. 0.01 -> 0.02 -> 0.03 and so on) during more than 8 hours. There was no reaction on keyboard, power on/off. But after all I pressed Reset/Diagnostics button when LCC was "Off" and switch it "On" and release button after 2 seconds and our LCC showed "Check Code 191". I.E. I did "master restart" once more. After that LCC-501 is ok and works properly.
Posted on Jun 30, 2017
Someone has pressed the reset button at the back of the unit. The memory banks are being cleared and all settings are set to default. Wait until the process finishes (hour maybe) and till the "check code 191" is displayed. This means that the restore to factory settings is finished. After that you should be able to use the unit again although all your programs are lost.
Posted on Oct 07, 2014
2 Suggested Answers
SOURCE: Error Message 103
I think it maybe because you haven't installed the "Driver" either at all, or properly. Uninstall any/all software. Reboot, DO NOT plug in unit. now, re-install the Software and Driver. Reboot, NOW plug in the unit, it should now be detected, and work.
You don't say what OS you are using? If Vista or Win 7, try installing as Administrator and also set Compatibility Mode for XP SP2 and run the main .exe as Administrator too.
Posted on Feb 12, 2010
Display message meaning
Is zone 6 only in program C? If so, it's simply telling you that the current draw is beyond the controller's capacity which I believe is either 1 or 1-1/4 Amp. In which case the Valve solenoid may be shorted. If Zone 6 is also set to run in any other Programs and does not indicate a short, then the Controller likely is at fault.
Apr 05, 2014 | Kitchen Appliances - Others
Hi I need the service manual for pharmacia lkb eps 500
Hey, I have a 220V version. If you want I can send you some pics, well, if you didn't already fix the problem!
Apr 16, 2013 | pharmacia Lkb, Model Eps 500/400 Power...
Manual for mcx-8 reactive controller
Controller and Analyser
Share: zero.gifzero.gif zero.gifzero.gifzero.gif Reactive power controllers MCE and MCX are designed to measure the reactive power of an installation and to give the necessary instructions for connecting & disconnecting capacitors in order to maintain the desired cos ö.
All the controllers are commanded by a microprocessor that ensures an uniform ageing of contractors and capacitors by using a circular connection sequence that takes into account the time that each capacitor has been switched on.
Power factor value to be reached can be adjusted in a continuous way, between 0.85 inductive and 0.95 capacitive.
Standard working programs for controllers are 1:1:1:1, 1:2:2:2, 1:2:4:4, 1:2:4:8 and 1:1:2:2.
*Item Code: MCEzero.gif
Power factor controllers MCE measures the cos ö of a supply system and control the automatic connection and disconnection of compensation capacitors according to the desired cos ö. They are available in 6 or 12 steps. To see the technical specification and for these steps please go to the attached Pdf file.
*The MCE-12F plus (12 steps) power factor controller measures cos ö in the system and regulates the automatic connection and disconnection of the capacitors depending on the required cos ö. MCE-12F plus is specially designed to control equipments with static switches based on thyristors, which operate through a zero step controller. *
These reactive power controller are designed to measure the reactive power of an installation by giving the necessary instructions for connection and disconnection of capacitors in order to maintain the desired cos ö. Controllers are show in a 3-digit display of the set-up or actual values. They show the cos ö, that the total current & the harmonic distortion.
All controllers are commanded by a microprocessor that ensures an uniform ageing of contactors and capacitors by using a circular connection sequence which takes into account the time that each capacitor has been switched on (FIFO system).
Controllers can include a fully operational alarm relay that acts when the automatic capacitor bank cannot reach the required cos ö in case of high harmonic distortion level, over-current and over voltages. LED indicators show permanently capacitors steps that are connected. To see these steps please open the Pdf file.
May 02, 2011 | Computers & Internet
I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote controller, or the RESET button on the control panel,
while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
3. Press the and select 0, and wait until the timer display is cleared.
Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
LCC-K1000 LG Dynamic Controller manual
Hello to the text ready Control camera type lcc-k100 dynamic controller Forgot Password and I want to replace it possible answer
Oct 27, 2010 | Cameras
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
Error message
I got the solution from someone else. Here it is: try this website. Scroll down to step number 5. Works great :-)
Aug 30, 2008 | Texas Instruments TI-83 Plus Calculator
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Science & Laboratory Logo
1,855 people viewed this question
Top pharmacia Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a pharmacia Science and Laboratory Expert? Answer questions, earn points and help others
