Question about Xerox DocuMate 152 Pass-Through Scanner
Xerox documate 152 scanner - won't scan
I can put the paper in and it seems to start the scan - but stops at 98% or 99% when taking the paper through. I have turned the scanner on and off and rebooted the computer. I have uninstalled and reinstalled. And the driver is up to date. I have Windows 7 and Office 2010. It worked OK before the hard drive was replaced recently. The computer is just over a year old. What to do now?
  • Laurie Bailey Oct 30, 2012
    It was plugged in but apparently not well enough. I tried two ports and they both work. SO glad it was an easy fix. Thank you very much.
    Scholar:
  • 34 Answers
Hello.
I am a Support Engineer with Xerox Scanners.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410xerox documate 152 scanner - won't scan - bsat4ube4gblqiaaaaasuvork5cyii=.
Regards,
Xerox Scanners Support
Posted on Oct 30, 2012
jomabug76
  • 1148 Answers
SOURCE: The twain driver from xerox for documate 510
xerox website for support and driver downloads
Posted on Nov 03, 2010
  • 36 Answers
SOURCE: xerox ducuMate 152, password recently does not work
You could reset the device, that usually resets everything - the downfall is that you will have to re-configure everything.
  1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu.
  2. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 152 scanner.
  3. Click the Properties button.
  4. To return the scanner to its factory settings, click Reset Device.
  5. Click OK to save the changes and close the dialog box.
If this doesn't fix the problem please post a comment, I will do some more research into it.
Posted on Mar 20, 2009
candgbabu
  • 53 Answers
SOURCE: I have a new laptop now with windows 7. I
Using window 7 scanner driver and try again
Posted on Mar 23, 2011
  • 7 Answers
SOURCE: i have been using my Xerox 152 scanner for a year
Okay, I brought on my feminine side and read the manual. I cleaned the rollers etc and located the extra 'pad assembly ' that came with the scanner. So I hope I am all set for awhile.
Posted on Jan 10, 2010
  • 7 Answers
SOURCE: Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Epson gts50 wont stop scanning until paper jam occurs
I just started having the same issue. However, I don't think the problems was understood. You can one sheet of paper; that's all you need to scan. The scanner will not stop until it has cycled through 8 scans and which point it will then prompt that a e1: Paper Jam has occured. You can hit ok and still safe the document, but it is annoying have to go through the cycles or hit cancel to stop the cycling (at which point you can then still save the scan). I believe Alan and I are both looking for a solution to resolve the issue.
Mine started after a serious paper jam. I am in a rather unique situation as I have to requested elevated priveledges to down load/update any drivers. So personnally I am trying to find a way to work around the issue.
Thoughts would be greatly appreciated.
Jan 13, 2014 | Epson Office Equipment & Supplies
Hi, i have a Canon dr 9050c scanner. I have the folowing Problem: When the Scanner power on then the Tray move up and down. if i start a scan from PC than can the Scanner not lift up the tray. It sounds...
It sounds like you diagnosed it.
The tray "paper detect sensor" thinks it has paper in it, and if it doesn't have paper in it...there's a problem with the sensor.
Take the tray off and inspect the sensor. Blow out around the sensor and it's PCB and make sure it is not out of position. Check the sensor lens for anything blocking it, and retest. If it still shows always on, then replace the sensor. Press the "count only" button to illuminate it, and press the "start" button. If the scanner works properly (tray lifts, pulls paper through the scanner, and counts it)...well then you have software or connectivity issue.
Hope that helps,
Scan-R-Store Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Aug 26, 2013 | Canon DR Office Equipment & Supplies
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
Canoscan 4400f delivers different colour vertical stripes low saturated but enough to make scan unusable. Have cleaned mirrors to no effect, cannot access the lens for cleaning, seems hidden in body of...
if u are scanning from a document feeder then its a spec on the glass as the paper passes over this spec the scanner reads as though the spec contiues all the way down the page
if it occurs from the flatbed scan i would suggest its dirty fuser or transfer roller
u can try a stop test by scanning a document and asking for 10 prints stop it after 2 prints and open the machine and remove the papers that are halfway through the machine this can help u narrow down exactly where the print defect starts from
Jan 19, 2011 | Office Equipment & Supplies
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
www.RadioReference.com
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Feeding problem
There are quite a few optical paper sensors in any scanner. If one of them is blocked by a shred of paper, the scanners 'assumes' the paper is available and starts scanning. Try to blow air and clean the scanner. Take care not to damage the sensors. S. Mohan, India
Dec 24, 2008 | Canon DR 2080C Path-Through Scanner
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Error Code 009 Scanner out of paper
Right-click the VRS icon in the system tray. Select QC Modes and uncheck Hardware Errors. This will stop VRS from flashing the out of paper message.
(Also, ImageNow has it's own prompt when the scanner is empty. You can turn that off in the Scanning Profile on the Properties page.)
Oct 16, 2007 | Canon DR-9080C Path-Through Scanner
Xerox DocuMate 152 Pass-Through Scanner Logo
1,276 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
