Question about Amana Kitchen Ranges
NO power to new bake element
Replaced blown element ( had a hole in it ). New one does not even get warm,all other elements , broiler, warming drawer, burners, etc. work fine Model # AER5845QAN
  • 163 Answers
Hi!!! make sure that all hi- limit switches are working.If you can find the diagram look for hi--limit swith they might be bad..Also check the wires going to the control board to the element it might have gotten loose or if not you might have a bad board pc board.Good luck.
Posted on Jan 03, 2009
Frigidaire - Professional Series - Gas/Electric Range - Replaced bake element but now Broiler and Bake elements don't work
Go outside to the breaker panel on your house and reset the oven breaker a couple of times. It will be 2 breakers side by side with the switch handles bound together. What happens is if one trips but not both, 240 volts is not present but 120 is. that's why motors and lights still work. If the breaker has some age on it just get the number off it and replace it.
May 24, 2015 | Kitchen Ranges
Yes. It gets red when it is heating; it'll go on and off to maintain oven temp. If it doesn't work at all it could be loose, burned out, to other electrical problem.
Apr 16, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Broil element just warm, bake element not working
Hey -have ya tried checking the power block on the back of the stove? This is the first thing I check when power appears to be uneven. Connections may be loose enough to disrupt power flow to the elements. If wires look good, the next step is to find out if the bake element has failed. From the back you can see the wires that attach to the element. Disconnect and check resistance.  should be around 17-19ohms. If not replace with new.  Please acknowledge this post if the info was helpful. Have more if needed  Thanks-- Ed
Mar 20, 2010 | Moffat Ovens
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
81 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
