Question about Kenmore 15864/15862 Top Load Washer
Odor My washer hasbegan tohave an odor and is causing my Clothes to have the Same smell.
I think that you may need to clean out the water pump filter as this clogs up with smelly sludge you may also find a few coins for your trouble....
Posted on Jan 03, 2009
The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See:
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
Dec 19, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Foul water smell coming from washer after using machine.
Check the hoses to make sure there are no leaks or standing water behind. Try running a cycle or two of vinegar water and baking soda water to kill any mildew that might be in the tub.
New washers often give off an odor described as a burning match or electrical smell. This is normal and is caused by the "wearing in" of clutch shoes and the heating of new paint on the motor windings.
Older washer odors are usually caused by leaving the washer lid closed when not in use. This does not allow air to circulate and dry out the moisture remaining in tub area. The air and moisture mixture becomes stagnant and creates an odor. When washer is not in use, leaving the lid up/open for air circulation will help prevent odor.
To get rid of odors inside of washer follow the steps listed below:
  1. Fill the washer with hot water; set at regular speed & longest time.
  2. Add 3/4 cup of Calgon Clothes Detergent. (Baking soda can be substituted) .
  3. Allow washer to complete entire wash and rinse cycle.
  4. If odor lingers, repeat entire process.
Oct 18, 2009 | Washing Machines
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Duet washer has a strong odor when draining
you might be getting "sewer gases" from your drain, but most likely your washer is the cause of the odors.
does it also smell musty when you get your clothes out?
whirlpool makes a product called "affresh" that is specially designed to clean out the residues from a front load washer.
you can find them at sears or lowes and the come in a package of 3 tablets. run a tablet on the clean cycle or on whitest whites or the longest cycle you can choose, use hot water and a second rinse option.
also to prevent this odor in the future make sure you are using only HE type soap and dont use too much. the least amount should do well to clean any clothes.
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Sep 30, 2008 | Estate TAWX700JQ Top Load Washer
The clothes smell if left in the washer wet overnight
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Jun 07, 2008 | GE WHRE5260E Top Load Washer
Kenmore Washer Odor
I've been selling the only available all natural washing machine and towel mold and mildew remover online at since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See:
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
49 people viewed this question
Sal De
 Brian Main
Brian Main
