Deville propane stove
I'm looking for a replacement thernocouple for a Deville Propane stove model #5555
  • 109 Answers
SOURCE: ritetemp propane log
your pilot assy is clogged, disassemble the pilot assy completely and inspect the orifice. there should be a tiny pinhole in the end of the orifice, clean well with small wire brush and reassemble, don't forget to clean the thermocouple while you have the assy out.
Posted on Mar 30, 2008
Accurate Joe
  • 61 Answers
SOURCE: Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Posted on Nov 30, 2008
SOURCE: my rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Posted on Dec 22, 2008
SOURCE: My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Posted on Nov 22, 2009
motor1258
  • 6674 Answers
SOURCE: I have a Trane XE70 Propane Furnace. The furnace
Unfortunately it's not uncommon to have to hold that pilot for what seems like forever to get that air out now. I usually hold pilot and wait 5-10 seconds or so in between trying to ignite. I've had some that people have spent a half hour trying, and I walk in and it lights for me first try. ha-ha, Like I was magic or something, then I've had others where I've spent 10-15 minutes, and was ready to give up for a while and come back, but tried it once more, and away it went. Trying to get lots of air through that small pilot takes patience. I have another way to do it too, but It's better I don't tell you that procedure yet.
How long have you held it on pilot so far?
Posted on Nov 06, 2010
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
What kit do I need to convert to propane, or is it built into the stove? Got it used
Look under the top cover of the stove top. They may be in there. If not, you can get them online or at an appliance parts store. Just google propane conversion for the make and model of your stove.
Dec 18, 2015 | Kitchen Ranges
I have two magic chef model 6157wuw ranges in my house which operate on propane. The stove burners work perfectly however the ovens produce no heat, no smell of propane and no sign of a pilot or glowing...
It sounds like your propane line is obstructed or your igniter has failed. If your igniter has failed, the propane will not flow until a heat source, from your igniter, has heated a sensor to let the unit know to allow propane to flow. If the propane line is obstructed, it is probably a spider web or eggs from an insect. A pipe cleaner is the best way to remove these obstructions. It would be advisable to have a qualified technician look at your unit.
Sep 21, 2013 | Magic Chef Kitchen Ranges
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
I just changed out the o2 sensor in my 1999 cadillac deville and now the same one is showing as bad what is the underlying issue?
Have you checked for engine vacuum leaks at the intake manifold gaskets and any leaking engine vacuum hoses? Use propane to run this test.
Jun 19, 2011 | 1999 Cadillac DeVille
My propane oven takes over an hour to preheat. I have lots of propane, what could be wrong?
Weak ignitor. The ignitor must draw 3.5 amps to open the safety valve. Take a look at the ignitor if it is strong it will blind you and light the oven in less than 2 minutes, it will be a dim orange color and take fifty forevers to light off. Bumping the stove makes it light off. Replace the ignitor.
Feb 04, 2010 | Kitchen Ranges
Propane was turned off for unrelated problem propane turned back on stove will not lite
If your stove has a standing pilot, it will need to be re-lit.
If this does not help, state the model of your stove.
Apr 28, 2009 | Kitchen Ranges
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
