Question about Broan-NuTone Dryers
S80uec bath fan
Can i test the motor by bypassing the capacitor
3 Suggested Answers
SOURCE: where can i get a replacement motor for a qt100l BATH FAN?
Go to the link below and you can order replacement parts for the QT 100L
http://parts.broan-nutone.com/nutone/Shop?DSP=30115&PCR=1:21000&IID=QT100L
Posted on Dec 02, 2008
hondo73162
  • 132 Answers
SOURCE: Fan does not work motor will buzz thats all. Nutone ultra quiet t
it may be that the bearings nead to be oiled, have you tried to spin it by pushing it with a pencil and see if it sticks or spins freely ?
Posted on Nov 07, 2009
Need replacement motor for bath exhaust fan.
Best place usually is grangers if you just need a motor. Take in motor and they can match up the exactone for you.
Jun 09, 2015 | Patton Dryers
Freezer chest not cooling but Compressor is running
Unless you have a microfarad capacitor meter, you won't be able to check the capacitor. Make sure the evaporator fan motor is running. You may be low on refrigerant.
Feb 22, 2015 | Refrigerators
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly.
Just go to You Tube and search on Broan
Sep 16, 2014 | Broan-NuTone Dryers
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Replaced condenser fan motor with OEM and I replaced the dual run capacitor with exact same rating and the condenser fan motor still will not run, I wired the way it came off (3wires brown to f on...
One way to test the motor and the board is to bypass the board. You need to direct wire the motor and test to see if it comes on. Then you know the motor is good and the board is bad. Not sure exactly what board your talking about though. Condensers don't have defrost timers on them. Can u post your model no. and any pictures of the unit would help also.
Aug 04, 2013 | Heating & Cooling
Can i test run the fan motor by bypassing the capacitor
Maybe: If you can manually rotate the motor to get it started.
The capacitor is on start winding, and causes sudden release of amps that starts the motor.
There are two (or four) windings in each single phase motor.
Both receive power at same time.
One winding is the start winding, which can be considered 'low gear' on a transmission. The capacitor is on this winding and gives burst of enough power to begin rotation.
So when a motor just hums, and doesn't rotate, then the start winding and/or capacitor are suspect. Dry or worn bearings are suspect too.
The other winding is the run winding that brings motor to up to speed.
On fan motor, the run winding can have multiple connection points for selecting different speeds.
Illustration.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Nov 01, 2012 | Broan-NuTone Dryers
I purchased a reoplacemetn motor for my Nutone/Broan LS 100SE bath fan based on a reccommendation here. The new motor, part # 89169, came with five wires compared to the original motor's three. How do I...
The additional wires are for a starting capacitor, not included with the motor. The easiest way to hook-up is to order the Outlet Assembly p/n 88617000 (available at Coastal Tech Supply.) The assembly includes the capacitor, connector, and shroud; and will replace the existing outlet assembly in the housing. Minor electrical work is required to remove the old assembly and install the new one.
Mar 03, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Low and medium fan speed no longer works on our Hampton Bay fan when you pull the chain. The high speed works. Can this be fixed with a repair part?
the speed is controlled by a capacitor bank ... high speed uses no capacitors, low speed uses a small capacitor in series with the motor and medium speed uses a larger capacitor ... the pull chain switch selects which capacitor is used ... so if the capacitors go bad or if the switch fails to select them then you will not have low and medium speed ... so you could have a bad speed capacitor block or a bad switch or wiring that has come loose inside the fan (that connects the capacitors) .. all are replaceable .. i would first remove the covers from the fan and check all wire connections .. check the switch to see if it operates smoothly .. then suspect the capacitor block .. if you were an electrician then you could bypass the switch to test its function but if you are not then make sure power is off while working on the fan .. you should be able to get a new capacitor block from the manufacturer .. most are similar if they will phisically fit in the fan housing and have the same connectors ..
Aug 15, 2010 | Hampton Bay Heating & Cooling
Broan bath fan motor has bad bearings.New motor or new bearings?
The motor is usually not repairable. You can sometimes purchase the motor and fan separate but that is about it. Here is a link to a blog about replacing motors.
http://nutoneproducts.blogspot.com/2009/05/broan-bath-fan-motor-replacement.html
Oct 13, 2009 | Broan-NuTone Dryers
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Dryers Logo
42 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
