Question about Remington Garden
Need part # for oil cap on chain saw ES1514AS
14Inch Limb and Trim Remingon Chain saw #S1514AS
  • 188 Answers
SOURCE: looking for owners manual andoil cap
Here is a link to the owner's manual you requested... http://12.153.20.74/manuals/120877-01C.PDF . I suggest you contact the parts department at 800-446-1446 or online at www.masterparts.net , they should be able help you get the oil cap for your unit. Thank you
Posted on Apr 20, 2009
  • 188 Answers
SOURCE: no manual
Here is a link to the owner's manual you requested... http://12.153.20.74/manuals/107990-01G.pdf. I hope this helps you...
Posted on Jun 23, 2009
  • 4088 Answers
SOURCE: i was using my Remington 14'' limb N' trim chain
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Posted on Mar 21, 2010
dontbother10
  • 2220 Answers
SOURCE: plastic cog stripped remington
You provided no model number; you need it to find parts on the breakdown here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If it returns NLA try a part number search here, sometimes they still have the part.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Are you aware RemingtonPower is no longer in production? Often eBay is the only source. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
Posted on Apr 10, 2010
wentlanv
  • 710 Answers
SOURCE: Need replacement chain for remington
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
Posted on May 09, 2011
Why does chainsaw leak chain oil so fast
check for a missing jet at the end of the oil line near the chain sprocket
Jan 21, 2016 | Remington Garden
What kind of oil
you need bar and chain oil you can get it at most hardware stores
Jun 17, 2013 | Remington Rm1415a 14" Limb N Trim Electric...
What kind of oil do i use for my remington 14 in limb and trim
Hi, I'm assuming you mean the oil for the chain. If so any brand of bar and chain oil is fine. Hope this helps, regards Phil.
May 25, 2011 | Remington Electric Chain Saw
Need replacement chain for remington 14inch, EL-1 and remington LNT Limb N' Trim 8. Could you provide me with current replacement chain information for both?
Hi jvaltha,
Handie Andie
May 09, 2011 | Remington Electric Chain Saw
I have a Remington 14' Limb n' Trim electric chainsaw. There is an oil reservoir (I think - it has a little rubber cap) and I am not sure if it is for motor oil. If it is, what type of oil should I use?
jmccabe2465-
The reservoir is for bar chain oil, which all chain saws require to allow the chain to operate smoothly and reduce heat build-up from friction.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Remington Electric Chain Saw
I have a reminton 14inc limb and trimb. What kind
Use regular bar and chain oil available from home centers, hardware stores, and saw dealers.
Jun 08, 2010 | Remington Electric Chain Saw
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
Mar 21, 2010 | Remington Electric Chain Saw
Where can I get parts for my remington limb n trim chain saw model # lnt-2, serial #037215
Your model is LNT-2 you can find an IPL here:
I recommend you print it. Click the part number you need. HTH
Lou
Sep 26, 2009 | Remington Electric Chain Saw
Do not have manual and need one. Do not know what type of oil it uses.
According to the manufacturer, "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." I will need the actual model number of your saw (it should be loacted on the saw it's self) to see if I can find the manual for you. I hope this helps so far...
May 27, 2009 | Remington Electric Chain Saw
Looking for owners manual andoil cap for reminton chain saw es1514as
Apr 18, 2009 | Remington Electric Chain Saw
Garden Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
