Question about Singer 7466 Mechanical Sewing Machine
Singer 7466 bobbin winding problem
When I try to wind my bobbin the machine works fine for about 1 second then it completely stops, beeps a high pitch beep, and flashes 88 across the screen. I JUST opened the sewing machine, it is brand new. What is causing this? How can I fix it? Thanks.
  • Anonymous Apr 13, 2009
    same problem. Try to wind my bobbin and it will be just fine and then stops and flashes "88"
SOURCE: Singer 7442 Bobbin Will not wind
to wind a bobbin you get thread and put it where it usually would be put it behind those 2 metal piece (see pic in manual) and there put it around the thread guide and then u put the tip of the thread through the hole of the top of the bobbin from the inside to the outside  and u are really to start, u should already have the bobbin and the spinning metal piece, then u move the metal piece to the right into the notch and press the presser foot and hold it until it stops you and you're done :-)
Posted on Mar 27, 2008
  • 106 Answers
SOURCE: Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
Posted on Mar 28, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
nenndre
SOURCE: Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
I have a singer 7466 and the bobbin won't load error code 88. please help!
An 88 error code is a generic one. It could mean that the needle isn't moving properly when the machine is turned on, there could be a problem at the bobbin or the computer for the machine is compromised. When did the error occur (regular sewing or bobbin winding)?
First, make sure that the needle is at the highest point with the hand wheel. Turn the machine off and then back on. Does the needle move to the side and back to the center? If so, then the problem is elsewhere. If the needle didn't move, I'd still recommend that you clean the area under the bobbin case.
If you were winding a bobbin, try a different bobbin. Check for any burs that might block smooth rotation of the bobbin. If you were doing regular sewing, also try a new bobbin. Check the bobbin case and hook areas for lint and clean them out.
If the error still persists, the machine needs to be serviced.
I hope this helps.
Jan 18, 2017 | Singer 7466 Mechanical Sewing Machine
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Can't seem to wind a bobbin on Singer 7466 .
HI, THERE ARE SEVERAL THINGS TO LOOK FOR WHEN YOU ARE WINDING A BOBBIN. FIRST CHECK YOUR THREAD, IS IT ON THE MACHINE GOING IN THE CORRECT DIRECTION. SECOND CHECK TO SEE IF YOU ARE THREADING THE THREAD THRU THE BOBBIN AREA ON TOP OF THE MACHINE CORRECTLY. I AM NOT FAMILIAR WITH YOUR MACHINE, BUT MOST HOME MACHINES HAVE THE BOBBIN THREADER ON TOP...THIS IS WHERE PART OF THE TENSION NEEDED COMES FROM TO WIND THE BOBBIN. NEXT, DOES YOUR MACHINE REQUIRE YOU TO LOOSEN THE TENSION ON THE WHEEL, OR DOES YOUR MACHINE HAVE YOU MOVING THE BOBBIN POST BEFORE IT WORKS. LASTLY, CHECK HOW YOU ARE ADDING YOUR THREAD TO THE BOBBIN AND PLACING IT ONTO THE BOBBIN HOLDER, IF IT IS NOT CORRECT IT WILL JUST SPIN OFF THE THREAD. I USUALLY LET THE THREAD GLIDE THRU MY FINGERS AT FIRST TO MAKE SURE I HAVE THE CORRECT TENSION. SOME MACHINES HAVE A TENSION SCREW THAT YOU CAN ADJUST THE THREAD TENSION. IF YOU DO NOT HAVE A MANUAL FOR YOUR MACHINE, GO TO SINGER AND MOST LIKELY THEY WILL HAVE ONE THAT YOU CAN PURCHASE. I HAD TO BUY ONE ONCE AND IT WAS ABOUT $15.00, MAYBE THERE IS A SITE YOU CAN GET ONE FOR FREE I DON'T REALLY KNOW. HOPE THIS HELPS. JUST A SLIGHT THING NOT CORRECT AND YOUR MACHINE WILL NOT OPERATE CORRECTLY, SO IT MAYBE JUST YOU HAVE SOMETHING BACKWARDS OR YOU NEED TO LOOSEN THE FLYWHEEL OR MOVE THE BOBBIN PEG.
Jun 17, 2009 | Singer 7466 Mechanical Sewing Machine
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Problem winding the bobbin movement of needle doesnt disengaged , then all lights light up as if its a warning after one winding a maximum of two times. singer 7422
Check the buttonhole switch ,if not there there is a microswitch on the bobbin winder that may be out of adjustment
Oct 24, 2008 | Singer 7422
I accidentally used 220V for my singer 7442, I don't know if there is a fuse that I can change? can someone help me with this?
Jan 19, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7466 Mechanical Sewing Machine Logo
89 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
