Question about NEC Televison & Video
I cannot get a picture to show up. It will show the word VIDEO 1, 2 ... and the TV's menu's but no tv program. We have tried switching time warner cable box but that didn't work either.
  • NEC Master
  • 8,617 Answers
The main board would be suspect since its not processing any signal input from any of the inputs. Try www.tvcircuitboards.com they should have a replacement board available.
Posted on Oct 31, 2012
  • 52 Answers
SOURCE: This TV won't support 1080!
I have this same TV, and cable from Comcast (which uses the same Motorola Box as Time Warner). Are you using component output from you CATV box, or HDMI to DVI. Your TV has two component inputs and one DVI input, but no HDMI input directly. If you use component, you must do two things. 1. The TV is auto-sensing as to the input signal, and will work with 1080i, 720p, 480p or 480i. Make sure you have a good grade component cable. 2. On your CATV box, turn the power off with the remote, then within 3 seconds press 'MENU'. This will give you a screen where you can specify the output from your CATV. I suggest 1080i, but 720p works fine, too. If you are using the DVI input, then you must be using an HDMI to DVI converter cable or adapter. To make this work -- THIS IS VERY IMPORTANT -- you must set the CATV box to HDMI output, not DVI. Use the same process as described above, but make sure your HDMI/DVI cable is connected, and you have selected the DVI input on the TV. Otherwise, you won't get the proper menu on the CATV box. BTW, the prior suggestion is not the problem -- low signal from the cable company would cause the picture to pixelate, but not lose sync. However, both problems COULD be caused by a defective CATV box. If they haven't already replaced the CATV box, tell them to do so immediately or you will call DIRECTV!!
Posted on May 30, 2007
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
SOURCE: Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Posted on Jan 10, 2009
SOURCE: My Time Warner cable Remote will not program to my TV.
I had the same problem, so I followed these steps and it worked!
1) Turn on TV.
2) On the remote control, press TV once (it will blink once). Then press and hold SETUP until the TV key blinks twice.
3) Enter 9 9 1, (the TV key will blink twice).
4) Aim the remote control at the TV & press POWER once.
5) Press & release the CH+ key continously (you may need to press it more than 50 times!), then stop when the TV turns off.
6) Press POWER. The TV should turn on, then immediately, press SETUP to lock in the code.
Posted on Aug 22, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
Can't get to program to Emerson tv
You need to look in the owner's manual that came with the TV. It should show you how to call up Menu and track through the setup of sound, picture, etc. If you do not have one, please send me the details of your Emerson TV including model number and I'll try to find one for you.
Jan 23, 2013 | Televison & Video
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Dec 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Tv 1 and tv 2 are in our bedrooms. my son wants to record his shows on his and i want to record on mine. all timed showed are going to tv1. we went into record plus and disabled it< but the problem...
Hi my name is Mike Houston of DISH Network and I see you want to have your son's recordings on his TV. If you will press the buttons of Menu-8-5 and select Disable and select Done, if your son's TV will not record on his TV please reset the receiver and allow it to power back up. After it has finished acquiring the signal and the Program Guide please try to set a recording for his TV, If the problem still persist please e-mail me at Michael.houston@dishnetwork and I will assist you further.
Sep 13, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a 32 inch tv, the picture only shows 23 inches
This is the tv station only broadcasting a certain size for the video. One way you can fix this is going into the menu and looking at zoom options. I use it all the time on my tv. If this doesn't work, call your cable company or your tv's manufacturer.
May 22, 2011 | Televison & Video
How do you switch to video mode with no remote
hi,
you cant.
your going to have to get a mid priced universal with extended features. read the packaging. thrift stores sometimes have a bag wall with old remotes so if you have someone who goes to the thrift store sometimes tell them to start looking for either a vcr or tv remote that says emerson on it for you. directv and dish network universals have video input buttons, if you have eith of those providers go to their website, download or find the chapter where it shows how to set up your viseo input. it is shut off by default..
jm
Apr 14, 2011 | Emerson EWF2004 20" TV
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Televison & Video
Tv works jsut no pic black and white screen says weak or no signel?
If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
To find the the correct video input:
1. turn On the device you are trying to see
2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
You program the TV by accessing it in the User Menu.
Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
Zenith advanced system 3, can't access video 1 or 2
I just got the TV for free with no remote and had the same problem.  The solution I found is to connect two devices that are feeding live signal (a VCR, DVD player, or game console) to the RCA connector input on the back of TV for Video 1 and Video 2.  I then used the first menu option which I accessed by using the Menu key on the front of the TV and Adjust and Select buttons to scan for channels and detect the band for the reciever to use.  After doing this I changed the setting away from "Fixed" (I forget which setting) and turned the TV on and off.  I then found that by pressing Menu several times I would get new menus.  Before I had done that scan with more devices attached to the other ports I didn't get any other menus.  I also discovered that depending on which devices I had connected I would get a Picture in Picture feature.  It would have its own menu to select its source, but I would lose that feature if I changed the device topography of my setup.
Sep 09, 2007 | Toshiba 27AF42 27" TV
Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
133 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
