Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
My projector only shows black and white images
Eventhough i have tried the color settin options i have not been able to set the colors. All I get is a black and white screen
    New Friend:
Not only images. even product logo is black and white in dlp projctor
Posted on Aug 07, 2015
Probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Posted on Jan 04, 2009
SOURCE:
Sir, its white small dots on complete screen, like sky with stars,
Place a white piece of paper about 1000mm in front of the screen and focus the image sharply.
Choose menu, image, advanced then select color manager.
go through the color options and check if some pixels are permanently on or off (ie small dots or black) instead of a uniform colour on the screen.
The DLP chip is most likely the faulty component
Mar 01, 2011 | Vivitek D825MX Projector
Sharp XR1S It projects the image on screen, use to show the correct color. last time the image was projected but in pink hues. is this an adjustment issue or is the lamp going or gone?
hi,
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
ok
Feb 02, 2011 | Sharp XR-1S Multimedia Projector
LCD projector (beamer) play all movies in black in white
Is the projector menu coming up just fine? if it is then it you signal. Try looking through the settings in the dvd player.
Apr 19, 2010 | Toshiba TDP-T90 Multimedia Projector
LCD projector not displaying color only black and white
Did you ever see color on this projector?
It could be the composite input cant detect the "color burst" 3.58 mhz signal for chroma.
Have you tried a different input?
That could help you track down what the problem may be.
Oct 31, 2009 | Televison & Video
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
In24in26
If you're getting a black and white image with or without source, it's probably the color wheel. Do you hear anything loose inside the projector? if you do it's the glass fragments of the broken color wheel.
Jan 06, 2008 | InFocus LP70+ Multimedia Projector
Only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Dec 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
1,040 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
