Question about Poulan Garden
Hello please I need the routing of fuel lines in a poulan pro 4218av
  • Poulan Master
  • 7,482 Answers
Hi Juan
I believe this is what your looking for.
Please rate me
Bud
hello please I need the routing of fuel lines in a - 10_31_2012_1_41_58_pm.gif
Posted on Oct 31, 2012
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
SOURCE: Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Posted on May 14, 2009
dontbother10
  • 2220 Answers
SOURCE: I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Posted on Oct 12, 2009
dontbother10
  • 2220 Answers
SOURCE: I need the fuel line routing or diagram for a
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Posted on Oct 23, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan chainsaw repair manual
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL for you saw can be found here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Posted on Jan 30, 2010
Poulan Pro model 185r fuel line routing
Just route it the most direct route from the tank to the carb
Apr 17, 2016 | Poulan Garden
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
I have a wt820 carb on an echo cs400 how do the fuel lines route
wt820-carb-echo-cs400-fuel-lines-route-u2zok31ofbeqiqkdplhepnij-2-0.jpg which is for the fuel line with the filter and which is for the primer bulb?
Nov 13, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
Primer bulb-carb routing
It should be like this.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need to know how to route the gas lines on a poulan pro 210 i notice the two sizes of line and there are two hookups on the carb which goes where
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan Pro 210 IPL.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
Jan 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
145 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
