Question about Fellowes Office Equipment & Supplies
Disable safe sense - Fellowes Office Equipment & Supplies
Gps nuvi screen sould it be to disable or enabled ?
This question makes no sense, the Nuvi screen should be on if you want to use the device. There is no option to disable the screen. if you mean simulator mode, keep it off or disabled.
Aug 03, 2014 | Garmin GPS
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Disable safe mode windows
Hello, It is not recommended that safe mode be disabled. Safe Mode is an alternet way that windows can be started in order to solve problems such as drivers that are corrupted and causes Windows in its normal start up state not to start properly. You can think of it as a special diagnostic mode for repairing your computer. Good Day.
Feb 09, 2014 | Computers & Internet
Can't open hertiage traditional gun safe
Has the safe suffered any jolts or drops during the move? Internal workings can contain components that lock the safe down if an attack is sensed. More details may help.
Jan 20, 2014 | Home Security
You can't disable Safe Mode in windows as it is used for trouble shooting the OS in times of failure. If you need to restrict access to Safe Mode set a password lock on the accounts on the machine and disable the guest account.
Dec 24, 2013 | Computers & Internet
Ok i have a Biostar P4M80-M4 Motherboard and i can not get it to sense any graphic card i own pci or agp. i have been told that i must disable the onboard graphics first and it wont work, i have tried...
Disconnect the hard disk and reboot - wait for its absence to be detected then shut down the pc , reboot and go into the BIOS and make sure the AGP is enabled. Shut down the pc again, insert the new video card, connect the monitor to it then start the pc and go into the BIOS - now you should be able to disable the onboard one.
Connect the hard disk and you're good to go.
Sep 05, 2011 | Biostar P4M80-M4 Motherboard
How to either turn off or disable "safe mode" at windows xp
How do I disable Safe Mode? (NT, 2000, XP)
Windows NT, 2000 and XP do not have any easy way to disable Safe Mode. However, there is a way to 'break' safe mode temporarily.
Doing this is not recommended. Proceed at your own risk!
Click on the Start Button
Select Run
Type in "regedit" and hit OK
Expand the left hand side to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SafeBoot
Under SafeBoot, you should now see Minimal and Network. Click on them and hit F2 to rename them to "Minimal-" and "Network-", respectively.
This should cause Windows to crash the next time it is booted into Safe Mode.
Nov 11, 2010 | Computers & Internet
Safe sense yellow light flashing, but shredder works fine
the flashing indicates a past jam or safe sense turned off . you can reset the error by following the instructions in the owners manual. if you do not have manual go to www.fellowes.com , support and download the owners manual for your model.
Dec 02, 2009 | Fellowes Office Equipment & Supplies
66 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
