Question about Topaz Systems SigLite 1x5 (z-t-s460-b) Touch Pad
Need drivers for siglite 1x5 pad - Topaz Systems SigLite 1x5 (z-t-s460-b) Touch Pad
3 Suggested Answers
SOURCE: SigLite 1x5 Model:T-S460-B (with serial connector)
The problem was not the topaz pad but my laptop. I removed all software which needs the serial port and I finished all not necessary programs which were running in the back but the problem was still alive. Now I asked my administrator for more rights and I changed the name of the port from port "1" to port "3" (port "2" doesn't work). I've got the message "port 3 is already in use" but the pc accepted the exchange of the name. Afterwards I changed the portnumber in the ini.file of the Topaz Software and now it works without any problems... strange, strange.... my five colleagues who are using the same pad on the same type of laptop (Compaq nc 6120) haven't got any problems during installation of the pad.
Thanks for your interest - kind: regards Ben Gun
Posted on Apr 17, 2008
micromatikal
  • 2777 Answers
SOURCE: We setup the Topaz Siglite
So you are trying to decrypt the signature? Is the encrypted signature successfully sent to your web server? Please let me know a bit more and I can definitely help.
Posted on Sep 09, 2010
Where is the egine number located
Depends on the make and model, the numbers are usually visible so in a event you are asked to verify you can see it without removing any fairing or parts and the numbers and letters are punched onto a flat rectangular flat surface area about 1x5 inches long. Most I see are near the oil level indows or next to the oil fill cap and sometime center of the lower half the engine. If you found the flat area without numbers and letters then you have a replace,net blank case.
Mar 15, 2016 | Motorcycles
Touch pad not working light bar not on above the touch pad
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
Jan 21, 2014 | Toshiba Satellite A205-S4617 Notebook
Mouse pad doesn't work on windows 8
I press <alt> F5 and it will turn on/off the mouse pad!!!
Feb 17, 2013 | Acer Computers & Internet
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
Jul 18, 2011 | Dell Vostro A860 Notebook
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Creda W200FW No: 45177606 washing machine have removed the PCB from a Creda W200FW washing machine and lost the info as to which plug goes where. Some are keyed and will only go on one place but some will...
Hi
I will try to help as best I can
  1. double red plug onto1x2 2
  2. double black wire plug onto 1x9 2
  3. blue black wire plug onto 1x11 2
  4. then 6 wire plug onto 1x5 6
This hopefully will solve your problem.
Please rate my solution.
Thanks.
Nov 11, 2009 | Creda W100FW Front Load Washer
Need touch pad advice
probably need a driver or at least an updated driver.
Also go into the control panel and see if there is an icon for the touchpad... double-click on that icon and look for settings to enable the scroll pad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Apr 06, 2008 | Topaz Systems TOPAZ SIG.CAP PAD SIG.LITE...
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
Topaz Systems SigLite 1x5 (z-t-s460-b) Touch Pad Logo
Top Topaz Systems Computers & Internet Experts
David Payne
David Payne
Are you a Topaz Systems Computer and Internet Expert? Answer questions, earn points and help others
