Question about Savin C2820 Black Toner Cartridge Genuine
Error code sc 386
I got this error code and want to know exactly what do I need to replace and where to order the part. Thank you
  • Carlos Rodriguez
    Carlos Rodriguez Nov 01, 2012
    Thanks to tech support from Ricoh find out that the code indicated a need for a replacement of the black drum unit. I ordered the part and am waiting for the delivery.
  • Carlos Rodriguez
    If you happen to know where to find the repair manual that shows the parts for this machine that will be great. The model is Ricoh c2820. Thank you
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
1 number
Posted on Nov 01, 2012
2 Suggested Answers
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
Code for samsung microwave
Can you please clarify what the main problem is so we can give you exact solution? I'm sorry I didn't quite understand what you mean. Thanks!
Oct 10, 2008 | Microwave Ovens
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Fase7073nwo
Good Afternoon Friend, this is Z. Thank you for your question!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
Jun 03, 2014 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 | Ovens
Washing maching not working
Hello would need the complete model number and the make of the machine to provide exact solution whereas Error code 51 for a kenmore elite, Calypso, Catalyst usually tends to point towards a defective rps sensor which is the small sensor located on the stator (motor ). I will await your reply in order to supply an exact diagnosis of your issue
Thank you
Rick
Nov 22, 2011 | Washing Machines
Error code E0990-0000
Kindly elaborate who you able to get this error code.
You need to put in details where exactly you get this error code and when it started?
You need to indicate as well on if there are any changes or if you had installed software or hardware before this error prompted?
Thank you!
May 27, 2011 | Computers & Internet
Codes po128 and po456 from engine warning light. are these actual problems or errors in the system? thank you
mazda codes are quit dependable when they set.they give the tech a place to start diagnosing the problem as codes never tell the tech what exact part needs replacing that`s not how the system works.
Apr 21, 2011 | Mazda MAZDA6 Cars & Trucks
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code tE, customer service recommended replacing thermoster, replaced but still getting error code. Can it be something else or does something have to be rest?
Ive looked through a service manual for your washing machine and that give the exact same fault and solution you mentioned (tE = Heater Error - The THERMISTOR is out of order)
Here is the service manual for you to look at:
WM-2277HW Service manunal
I had to scroll down to the troubleshooting section though but it has everything you would need to know in it.
I hope it helps
Regards
Mike
Mar 24, 2010 | LG WM-2277HW Front Load Washer
Savin C2820 Black Toner Cartridge Genuine Logo
121 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
