Typewriter types a few letters and stops
The typewriter will only type a few characters at a time. Turn it off and wait a period and it will type a few more characters. When it is not working it will not return or space. A faint clicking noise can be heard.
  • Dick O Reilly May 11, 2010
    How about a make and model.
Brother AX-25: I have the same problem.
I took the typewriter to a repair shop six months ago, the fixed the problem for $90, but three months later it started again. The problem starts as a small issue at first, but becomes untenable after a week or so. My typewriter would turn on, but when I would attempt to print, it would do nothing. There was that ever-present click, click, click...and I learned that if I turned it off and on several times, it would sometimes power up. After awhile, as I said, it will not work at all.
Repairman said he replaced the "main board", but I now doubt this, since the same problem has reappeared.
Ray H. Puckett Jr., MS/Orlando
Posted on Nov 18, 2010
    Scholar:
  • 183 Answers
No easy fix for this one. you will need to take this to a repair shop, check the yellow pages
Posted on Jan 06, 2009
Swintec 2640 Typing wrong characters
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
DickyO
Mar 17, 2014 | Swintec 2640 Electronic Display Typewriter
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
My typewriter is not typing letters or numbers, somehow it is typing characters that I do not recognize. I am told it has something to do with the ps on the left side.
The slide switch on the L. reads 15, 12, 10 and PS it should be in 10 or 12 if it is then slide it up and down a few times while pushing down on it. They fet dirty.
DickyO
Sep 19, 2011 | Nakajima AE-740 Typewriter
After typing a few words the typewriter starts to type all sorts of characters and symbols . If I reset it or turn it off, it will start out typing the correct letters for a few words again but then it...
Remove the printwheel and look for bent or broken spokes, look for debris in the P/W area, try it without the correction tape, if you have the wrong type tape or it is twisted there will be a problem.
DickyO
Aug 30, 2011 | Brother GX-6750 Typewriter
We have a swintec 2500 typewriter that when I attempt to press the letter "P" or any letter it types out a "period". Is there any feature to turn from one type of letter characters to another?
First be sure the printwheel is properly installed and that none of the spokes are bent of broken. Then check the pitch selector slide switch on the L. side of the KB it should be in 10 or 12 not in PS.
DickyO
Oct 13, 2010 | Swintec Office Equipment & Supplies
Typing characters that are not intended
Try these troubleshooting suggestions for your problem:
Wrong Characters Print or Characters Space Incorrectly:
1. Turn the typewriter off, wait 30 seconds, then turn the typewriter
on again and try typing again.
2. Make sure the LANG indicator is off.
3. Try a new printwheel.
4. Look for objects In the path of the carrier.
5. Make sure the printwheel is changed when there is a language
change.
6. If you are playing back, make sure you use the same pitch
printwheel you used when you typed the text.
You can download the Operator's Guide for your typewriter from here (it takes a little while for the download to begin):
Wheelwriter Typewriter 30 Series II (6787) Operator's Guide
Aug 20, 2009 | IBM Wheelwriter 30 Typewriter
Typing confusion
change CASSETTE DAISY WHEEL,
Jun 30, 2009 | Brother ML-100 Typewriter
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
Types wrong characters
If the typewriter is typing letters or symbols that you do not type, it is usually because the Pitch Selector is set to "PS". The pitch selector is on the left hand side and has the numbers 10,12, 15 and PS. Place the selector on 10 or 12 and you will be OK.
Also, check to make sure your printwheel is installed properly. Remove it and put it back in to make sure.
Another thing you can try is to clear the memory. To do this, turn off the machine. Place a piece of paper in the machine sideways. Hold down the MAR REL key and while holding it down, turn on the machine. Wait 2 seconds, then let go of the key. The typewriter will start typing. Shut the machine off after about 15 seconds. Then turn it on as usual. This will clear the typewriter's memory and unexpected charaters should not happen anymore.
Jay @ www.granadahillsbusinessmachines.com
Aug 20, 2007 | Swintec 7040 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
152 people viewed this question
k24674
jasbo
jasbo
