Question about Kenmore 34720 Upright Vacuum
Loud whistling noise from back of vacuum
I have a Kenmore Quick Clean vacuum, and when I turn it on there is a loud screeching whistle-type noise that comes from the back of the vacuum, from what I would call an air exchange. There is also a burning smell. The vacuum still picks stuff up but the noise is unbearable. This problem started happening after I emptied out the canister one time.
  • Anonymous Jan 23, 2009
    My vacuum is doing the same thing except it is not picking anything up. Also, there is no burning smell.
  • bfreer Feb 23, 2009
    We also have a loud whistling sound after a while of vacuuming. After cleaning out the dirt container, usually the sound is not there for a while, then comes back after vacuuming for a while.
    Sniper:
  • 84 Answers
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Posted on Sep 13, 2009
  • 125 Answers
Sounds like one of two problems
1 it may not be seated properl2 the bearings in the motor are shot
Posted on Feb 06, 2009
Loud whistling noise it is just going on five years old when I pull it backward a loud noise emmits
If you whistling is only happening when pulling back on the machine, the problem is with the connection between the bag housing and the swivel neck. There is a rubber gasket between the two, located on the bottom of the bag housing. Check to see if this seal is in place. If it is there and in good shape, check for excessive wear on either the swivel neck or bag housing. Windsor Sensor Vacuum Seal 5163 86144910 allstar javelin
Apr 02, 2014 | Windsor Vacuums
Shop vac whistles
If you let it continue, you will have a piece of junk. You take the bolts off holding the motor cover on and you lubricate the upper bushing with oil. They are oil impregnated bushings and will soak up a thin type oil best and last longer. Use 10W or 3-in-1 oil or Marvel Mystery oil.
Jan 01, 2014 | Shop Vac Vacuums
My Dyson 07 still seems to be working fine but it just started making a loud whistling noise. I looked for any air leaks but cannot locate any. The whistling noice is quite loud and annoying. Are we doing...
Sorry to hear you're having difficulties with your DC07. If you've been unable to locate the source of the whistling noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Makes a extremely loud alarm sounding noise while vacuuming and the cord in the back doesn't have good suction at all.
When you hear the whistling noise, means there is a clog either in the hose itself, or in the elbow where it goes in or from where the bottom tube bends and goes up. To clean hose, remove it, stick on top of broom/mop handle and push all the way down to clear out any debris on it.
Nov 20, 2009 | Bissell 6591 Power Trak Revolution Bagless...
Dyson DC14 Loud shrill whistle noise
Check and cleaning Brushbar Assy and Violet Cyclone Assy or replaced Brushbar Assy and Clutch Assy
Nov 04, 2009 | Dyson DC14 All floors Bagless Upright...
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Hoover bagless windtunnel has a whistle
when you take out the canister to dump it, there is a filter on the bottom.. take off and shake it out then put it back.. there''s also one on the top!!so when you replace thaton..look directly above that surprise anothe one do the same to that one and wholah like new
May 23, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Ear piercing whistle
Its an inherent problem with any Dynammite model = the fact that the motor is at the front means that it is extremely noisy.
Sep 30, 2007 | Dirt Devil M084600 Dynamite Bagless...
Kenmore 34720 Upright Vacuum Logo
550 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
