Question about Rolex Daytona 116518 Wrist Watch
Rolex Daytona Wrist Watch
Please advise on the correct functioning of the chronograph in detail and its movements please. Possible advise where a manual for this watch is avaliable. Thank you TommyD
  • 944 Answers
Try these guys for a manual; http://www.timemerchants.com/catalog.htm They have the 2000 daytona manual and several older ones available. Otherwise try your local Rolex dealer; http://www.rolex.com/en/collection/rolex-gallery/cosmograph-daytona/specification.jsp#/en/xml/inside-rolex/sales-service/affiliates/index Hope this helps :)
Posted on May 16, 2007
My daytona rolex has stoped working,iv tried all the slow and hard shaking movements and still no luck can any body help me please?
I'm going to venture to say that this watch is a counterfeit, has a quartz movement and needs the battery replaced.
Apr 27, 2013 | Rolex Daytona 116520 Wrist Watch
Rolex daytona
its not the manual, but this might help:
the three button chronograph would be brought together in the form of the 5034. During the next fifteen years the 5034 changed into the 6034, which then became the 6234. This in turn became the 6238 and then finally evolved into the 6239. These changes although little by little had inspired Rolex to revive the previously shelved name the "Cosmograph". The only difference between the 6239 and the 6238 was that on the 6239 the bezel was engraved with tachymeter graduations rather than having them on the dial. The last major changes to the manual wind chronograph came in the late 1970's when Rolex introduced the 6263 model. This was the first model to have truly waterproof pushers. The earlier Oyster Chronographs had simple round pushers with internal gaskets as the only sealing mechanism. The screw down pushers were added to stop people pressing the buttons, whilst submerged in water. The locking function also prevented the chronograph being activated inadvertently. The new 6263 started life as being waterproof to 165 feet, ten years later it was capable of twice that depth (100 meters) The 6263 is unusual in the fact that the quality of the movement depended on which case you had. The steel chronograph movements were not timed to a chronometer standard. Despite the innovative design it was not until 1986 when the popularity of the Daytona started to increase, reaching its zenith with a particular Daytona model, the "Paul Newman". This model featured square markers on the subsidiary dials, and an outer track the same colour as the subsidiary dials.
Dec 17, 2007 | Rolex Daytona 116520 Wrist Watch
How to know 78488 is original rolex
It's not a Rolex Daytona. Definitely fake.
Jan 14, 2013 | Rolex Daytona 116528 Wrist Watch
How to set Time in Rolex 116520...thnks a lot
The Daytona's Construction
  • Most stainless steel watches are made of surgical 316L steel, which is very good. Rolex goes a step beyond this, using 904L steel, it is both super corrosion resistant and highly polishable, which is why a Rolex shines like no other. Its bracelet is very easy to size adjust, using screws instead of pins. It is actually made of 100 moving parts that conform to the wrist with smooth edges that never snag or pinch the skin. The bracelet also has the Easylink system which lets you make a further adjustment when your wrist expands due to exercise and high altitudes. Rolex watches were originally intended to be a working man's watch and its construction is shock resistant, antimagnetic and water resistant. It achieves water resistance through its triplock system winding crown.
    You must first turn the watch crown counterclockwise until it releases from its seal. The watch crown will then pull out to let you either wind it or set the time. When complete, you must apply gentle pressure to it and turn it clockwise until it screws back into the case to protect it from dust and water. The Daytona caseback is hermetically sealed and only an authorized Rolex service person will be able to open it.
  • The Daytona's Movement
    The movement of the Daytona has changed over the years, it currently uses a 4130 caliber in-house movement. It is made of 290 parts which is much less than other Swiss chronograph movements. Its smaller size is efficient and precise and lets it fit into to the relatively small 40mm case. Note the size difference between the Daytona and the Tag Heuer Aquaracer. The watch movement also contains a Parachrom hairspring. This device protects the movement from magnetic fields and protects it from shock. On the front dial are the words, "superlative chronometer officially tested." This means the watch has undergone two weeks of testing under extreme conditions to meet Swiss standards. This process is standard for every Rolex with chronometer function. Using the Chronograph
  • The chronograph function can be first and foremost used as a stop watch. To start, press down on the button above the crown. To stop, press the top button again, and to reset press the button below the crown. The chronograph can also be used as a large second hand if you synchronize it to begin with the small second hand at six o'clock of the dial. It can also be used to calculate speed, which is a little more complex. It utilizes the units per hour scale that is engraved in the bezel of the watch. For example, suppose you have taken 50 seconds to travel 1 mile. Looking at the dial you can then determine your speed to be 72 mph. Average speed times can also be determined using further calculations.
  • Any other questions I would contact ROLEX at their website. They even have downloads. Good luck.
    http://www.rolex.com/en#/home/
    Aug 16, 2010 | Rolex Daytona 116520 Wrist Watch
    How to know fake or not rolex daytona 1992 ..
    Take a look on amazon for real watch prices (Daytona): Amazon com Rolex Daytona . After that you can compare. I hope this was helpful. Cheers
    Jun 12, 2009 | Rolex Daytona 116528 Wrist Watch
    Rolex daytona
    Rolex does not engrave the case back. If it says 24 hours at Daytona, or wording like that, the watch is not real... It's a fake, or as we say more kindly.. It's a replica, and can be bought on any replica watch web site for $30 to $80, for an automatic mov't.,  21J, made in China.
    Also, the sub-dials will not function on this watch. A Daytona needs the proper movement to operate the chronograph as it was intended..... To act as a stopwatch.. and measure time... seconds, minutes and hours. This is done by activating pushers at 2 and 4 positions, and the pushers on 21J replicas just don't operate a chron. for the purpose of measuring time. They may move and measure something else, like military time, or the date, but definitely not record seconds, minutes or hours. There are also no manuals on how to operate the Daytona that comes with these replica watches. You should know how this watch functions and how to operate the pushers, and what they do before you should buy and enjoy this type of chronograph watch. It's simple, just take the time to ask people in the know... how the daytona works, what the sub-dials measure and how to use them, etc. In no time you'll understand the operation of this beautifully made watch. Unfortunately, a daytona is out of reach for most of us... That's why seeking out a quality rolex replica for much less money is the way to go if you love this watch... A quality one can look, feel, and function just as good as the authentic Daytona, and you won't have to out out over $10K to get one.
    Regards,
    Doug
    Doug
    Jul 18, 2008 | Rolex Daytona 116520 Wrist Watch
    Rolex Daytona 116520 will not start
    no! you have not done anything wrong my suggestion is bring it to an authorized rolex service center or any certifide rolex watch fixers.to avoid any damage of your rolex daytona. it mabe costly but you have made it wisely.
    Mar 10, 2008 | Rolex Daytona 116520 Wrist Watch
    Rolex ad Daytona 1992 replica
    The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
    Doug
    Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
    Rolex wach booklet
    Try http://chronograph.homestead.com
    Dec 19, 2007 | Rolex Daytona 116520 Wrist Watch
    Rolex Daytona 116518 Wrist Watch Logo
    454 people viewed this question
    Top Rolex Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
