Question about Sewing Machines
How do you adjust the feeder foot tension on a Pfaff 1212?
Just got the machine back from the shop where he said I had somehow gotten the bobbin misaligned. Now I can't get the machine to sew forward. It first started only sewing a few stitches zigzag before breaking the needle. Now it only sews in one spot. I don't have a users manual and thought maybe it might be the bottom feeder foot.
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
If the looping is happening on the underside, it is your top tension that is to blame, conversely looping on top is bobbin tension.........take a look HERE for detail on cleaning lint buildup.
Top tension should be set around the middle of the range, usually 4 - 6.
I would not advise playing with bobbin tensions, however, you can take the needle plate off to clean the hook race area (where bobbin case sits) ...this is good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint, if there appears to be fine dirty deposits, a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit will do the trick.
Bargainbox
Posted on Jan 27, 2008
SOURCE: Sewing manual for a Reliable or Sailrite
The problem is that you purchased a clone of the Sailrite Ultrafeed. Most people do not know how much work Sailrite puts into each Ultrafeed Sewing Machine before it is shipped to customers. They hold 17 patents on the Zigzag Ultrafeed and know this machine inside and out. So when each machine goes through the assembly line in Indiana they are then tested by Sailrite in 2 layers of canvas then 8 layers of canvas then 4 layers of vinyl fabric if it does not sew it flawlessly they fix it, Ultrafeeds work right out of the box! So, it is highly unlikely that you will be able to get the clone machine to work. It must be totally rebuilt (a 4 hours process for an experienced technician). Sailrite will not work on any clone machines. So get your money back and buy a Sailrite Ultrafeed! If you are desperate and can not return the machine you can buy a DVD that Sailrite made for the Ultrafeed (each Ultrafeed purchased gets it free) it can be purchase here: http://www.sailrite.com/Ultrafeed-Advanced-Maintenance-DVD . It will help with timing issues, but will not show you how and what to do to rebuild the machine.
Posted on Jan 01, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Mar 10, 2010 | PfaFF Quilt & Craft Pro 7530
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
The bobbin stitch is not as straight and tight as the top stitch. I'm using the right needle for the denim a 110-18.  I have the tension set at 9 and I have played with it =all the way down to 0....
Try adjusting the bobbin tension. My Pfaff (with a front load bobbin) has a tension adjustment on the bobbin housing. When you take the housing out, make sure there is no lint or stray thread caught anywhere in the bobbin casing, load the thread. Then dangle the bobbin housing from the thread end. A gentle pull (more like a ****) on the thread should allow the bobbin casing to slide down 1/2 inch or less. If the casing falls too far, increase the tension on the bobbin thread. Good luck.
Dec 29, 2009 | PfaFF Sewing Machines
Pfaff 1475 tension problem.
Many users also reported similar bobbin tension adjust problems. But do you know it can be fixed by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Jun 21, 2009 | PfaFF Tiptronic 2030
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Mar 10, 2009 | PfaFF Creative 7570
Adjusting tension when stippling
Yes you should lower the feed dogs for free motion sewing. The tension can be set higher as required. A perfectly tuned up machine uses a setting of 5 but don't be afraid to go higher to get rid of the looping on the bottom.
Also, oil your hook every 8hrs with Pfaff hook oil (which is lighter weight than regular sewing machine oil) if you have it, otherwise use white sewing machine oil. Looping on the bottom can be caused by a dry hook.
good luck!
Feb 01, 2009 | Sewing Machines
Threading a pfaff 9020 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Jun 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
