Question about Garden
I need a impeller auger blade for my homelite Jacobsen 420 snow blower cheap
  • Garden Master
  • 2,478 Answers
Try e-bay
Posted on Oct 30, 2012
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
HW_Dude
  • 87 Answers
SOURCE: snow blower starts right up but dies once i engage the blades?
it is possible the engine is starving for fuel, so essentially it is a carburetor problem with fuel mixture.
Check and see if your carburetor has mixture adjustment needles, there may be an adjustment possible to fix this problem.
Also, sometimes a tiny vent hole in the carb caseing gets clogged causing the engine to run rough or stall.
Does your engine seem to run better if you close the Choke ?
Hope this helps you.
Posted on Jan 11, 2009
bbreton
  • 437 Answers
SOURCE: homelite / Jacobsen Imperial 830 Manual
I did a search for Homelite 52642. There are several sites out there with a type of manual running from 25-30 USD. Try looking at a search like I did. Did not see anything on Homelite's site. Maybe the unit is older than 10 years.
Posted on Dec 30, 2009
  • 8404 Answers
SOURCE: my 5hp 22 inchsnow blower
Could be the belt or more likely, a shear pin. I would lean toward a shear pin.
You don't mention the make so it is difficult to proceed.
Thanks for your interest today.
Posted on Jan 30, 2011
  • 144 Answers
SOURCE: I have an Ariens 1128
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
Posted on Feb 03, 2011
The impeller is turning but the blades are not. Belt seems ok
Depending on your make of snowblower, At the impeller there is usually 1 or 2 shear pins or bolts circled in red. If the impeller and the impeller shaft are turning but the augers are not, the gear may be stripped inside the gear box circled in yellow or the keyway may have sheared between the auger gear and the auger shaft.
Jan 24, 2016 | Garden
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Craftsman 179cc ohv 2 stage snowblower loses power in second stage throwing heavy snow
You should check for belt condition and adjustment. Under more load the auger/impeller belt might start to slip and would result in poor performance. For improved performance in wet slush there is an "impeller modification" that can be found with a web search. It's adding rubber wipers to the impeller blades and it does a great job of tossing that stuff out the chute instead of clogging it.
Feb 13, 2014 | Garden
Auger blades are spinning
sound like you might have 2 problems. If auger doesn't engage in heavy snow you probably just have ice accumulation inside the impeller. Dont try to engage until impeller is cleared of snow (shut off and unplug spark plug before cleaning) Second if blades are spinning than you must have hit something in your path and broke the shear bolt (about 2 bucks at hardware shop) remove the old bolt and replace it and it should work again if this is the problem. Good luck.
Feb 05, 2014 | Yard Machines Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
What is the right spark plug number for a JACOBSEN HomeLite 320E snow blower, model number UT35012A and seties SH3030001. Please help.
I recommend that you contact your nearest authorized service center, or contact Homelite directly for assistance.
I trust this information proves useful.
Sep 15, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Homelite / Jacobsen Imperial 830 Manual
Dec 28, 2009 | Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
