Question about GE XL1800 1100 Watts Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
GE above range microwave JVM 1860 SD 002. Turntable is very noisy and moves slowly. I tried taking off the glass plate, and it is still slow, noisy, and erratic.
Are there any easy solutions?
  • GE Master
  • 8,862 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 04, 2009
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have a JVM 1443bk02 ge microwave. Today the turntable stopped working. You can depress the key pad on/off button but that makes no difference for the turntable. How do you test to make sure it is the...
The problem with the turntable could be the following:
  1. Gummed up lubrication or bad bearings. Check to see if there is any food on the turntable spindle.
  2. If that is ok, check to see if the belt is loose or broken.
  3. If that is ok, check the motor. A meter will confirm whether there is power going to the motor, when you depress the keypad on button. Use the AC Volts setting, if you have about 21 VAC and the motor does not work, then the motor is bad.
Jan 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable has topped working.
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpfull, please rate my solution
Apr 24, 2009 | Microwave Ovens
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
Jan 28, 2009 | Microwave Ovens
Turntable does not fit on coupler
The correct part number is WB06X10144. Was that the number on the plastic bag it came in?
You can order it here for $7.37 and see a photo of it here:
Aug 15, 2008 | Microwave Ovens
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
823 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
