Question about Canon Cameras
How to clean/fix the sticky/melting handgrip of Canon camera?
I did not use the Canon EOS for some 6 years. The black handgrip has become melting/sticky.
  • Don D Jul 17, 2013
    I know it's old, but as about 50 people have viewed this, it seems to need an answer. I used alcohol (in the form of hand sanitizer, it was handy), paper towel (cut into small-ish pieces) and a lot of patience rubbing it off.
    If anyone knows how to remove the black grip altogether (300D), please reply - I would like to repaint it a fun colour before giving the camera to my child.
    New Friend:
Accidentally posted as comment, not solution, IMBNH :)
Posted on Jul 17, 2013
SOURCE: Canon Rebel EOS camera
Err 99 is a general error msg. That is, it has to be connected to the service soft that only Canon self or an ASF has, to know more precisely the problem.
To narrow the possibilities;
-choose Av, shutter priority,
-choose the smallest aperture your lens allows, 22 or 29 or so,
-while pressing and releasing the depth-of-field preview button, (front, under the lens release) look into the lens from the front.
If the diaphragm doesn't move it has to be changed. If you have the 17-55 standard lens; throw it away and buy a better one instead of paying a repair. You'd be better off.
If you have the Err msg with several different lenses the problem is in the body itself, often the shutter. Check also your PINs in the CF-slot. If one PIN is toching another; break off the bent one and normally you can go on, the PINs are almost all doubled.
Posted on Aug 05, 2008
  • 225 Answers
SOURCE: I just purchased a Canon
If you drop your camera in the dirt a lot, I would send it in for the cleaning. It just takes one grain of sand, if left to bounce around long enough inside your camera, to enter the lens assembly and jam a gear in the lens gearbox forever. Most sand will not jar loose again, and will require a repair to remove it. If you shake your camera and can hear dirt bouncing around inside, I would take the free cleaning service right away.
Posted on Nov 13, 2008
  • 9 Answers
SOURCE: Autofocus has failed on the CAnon EOS 40D. I can
It's not the Autofocus, there's no 'non-engineer' fix. Lens and slider have failed, it's basically broken inside and I suspect it was the original fault. It's about £160-200 outside of warranty to fix via a canon authorised repair agent such as www.camera-repair.co.uk in Colchester. Send it back, get your money back.
Posted on Jul 07, 2009
  • 11967 Answers
SOURCE: Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Posted on Aug 21, 2009
  • 80 Answers
SOURCE: error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Posted on Apr 06, 2010
I have a battery door that was cleaned and now is sticky, how do I get rid of the sticky feel? It was cleaned with alcohol.
Its very unusual for alcohol to leave a sticky residue, however try wiping over with vinegar, or even petrol that is for lighters. Put either on a cloth, (don't soak the cloth, just dampen it) and gently wipe, leave to dry. try that.
Jul 06, 2014 | Canon Used EOS A2E 35mm SLR Autofocus...
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
Black dot on my pictures.
This sounds like dust on the sensor. You'll need to clean it. Google the words "cleaning a DSLR sensor" and you will find sites explaining the procedure with pictures and info about where you can get the supplies.
Jul 23, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Rubber grips get sticky after a time instorage. How
Try using some rubbing alcohol on it. Should be able to clean it up.
Apr 12, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital EOS camera black spot in images
This is dirt on the sensor. You can clean this yourself but first, get some knowledge. Google the words...cleaning a digital slr sensor. You will find sites that will show you step by step what to do and what supplies you will need. It may seem daunting at first, but believe me, it is incredibly easy once you start.
Jan 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Autofocus has failed on the CAnon EOS 40D. I can power the camera up with lens in manual but as soon as I go to autofocus it becomes unresponsive. The viewfinder goes black. Swapped batteries and lenses....
Jun 30, 2009 | Canon EOS 40D Digital Camera
Problem with an old Canon EOS elan camera
Try an ammonia-based cleaner..but don't get it on the plastic.
Jun 22, 2009 | Canon EOS Elan 7 35mm SLR Camera
Sticky shutter blades
Canon EOS cameras manufactured in the late 1980s to early 1990s have an internal foam bumper for the shutter curtain which deteriorates with time, breaking down into an oily black tar. The tar oozes down and gets onto the shutter blades, causing them to stick. This results in the shutter either failing to open altogether or opening too slowly, resulting in blank or unexposed photographs.
cleaning procedure. Take a cotton swab and put a tiny bit of isopropyl alcohol or lighter fluid on it. Don’t drench it - you just want it slightly moist. Rub the tip of the swab on the oily patch, back and forth extremely lightly. You don’t want to apply any pressure, as the shutter curtain is fragile and easily bent and destroyed. Keep lightly rubbing the swab back and forth until the oil is entirely gone. Alcohol is a weaker solvent and so it may take a minute or two of gentle movement to dissolve the oil. Remember to do both sides of the shutter - you’ll have to move the mirror upwards to get the inner side, so don’t get any fingerprints on it. The easiest way to do this is to set the camera into mirror lockup mode (assuming your camera has the ability) and starting the self-timer.
That should fix the camera for the time being. Of course, the foam bumper is still there and continuing to degrade, so you’ll have to do this cleaning every now and again unless you pay to have it replaced. How often depends on your camera. Mine has gone for a year since the last cleaning without problems.
May 24, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Canon 5d lcd
If its a year, request that canon fix it free of charge under its warrenty.
Charge the battery, and or buy a new battery to see if its fixed. Bestbuy if there is one close to you is the first place I look for a battery.
May 20, 2009 | Canon EOS-5D Digital Camera
The rubber armoring is "melting" or getting all sticky
It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
Dec 11, 2008 | Bushnell Optics
Cameras Logo
187 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
