Question about Winix Dehumidifiers
Winix Dehumidifier Pump
Pump turns on, but no water flow. Removed slime from tank, tried to blow out drain tube with air, but no luck. Anybody else?
  • 4 Answers
SOURCE: Delonghi DE220 dehumidifier stopped extracting water from the air
You probably have a dirty heat exchanger. Write to me at j_sjohn@hotmail.com for free maintenance instructions on a smilar unit. Cheers.
Posted on Jan 05, 2009
  • 20 Answers
SOURCE: dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Posted on Sep 01, 2009
  • 105 Answers
SOURCE: This dehumidifier was set up to drain through a
Call a certified service technician.
Posted on Jan 29, 2010
heatman101
  • 43501 Answers
SOURCE: Whirlpool/Gold/Energy Star-Dehumidifier model:
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
  • 4736 Answers
SOURCE: My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Posted on Mar 23, 2011
After running for awhile the pump light starts blinking and the drain tube is not bent ?
Sounds like the plumbing is obstructed somewhere, try looking upstream as well as downstream of the pump. A very small piece of crud can cause a clot or embolism in the narrow channel. You might try blowing out the system with compressed air, but beware of getting showered with dehumidifier crud!
Jun 25, 2015 | DeLonghi DE500P Dehumidifier
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
Bucket removal is extremely difficult. What should I do?
There's usually a piece or tubing that hangs down into the tank and you need to pull your tank past this when removing it to drain your dehumidifier. Are you lifting from the top or bottom? Try the opposite of what you are doing. Sorry I don't know your model specifically, but often there's an outlet or cap at the bottom of the tank that can have a plastic piece of aquarium type tubing hooked to it. This way if you can elevate the whole dehumidifier, say on a counter, the water can just drain into a sink or if you're a real conserver into a storage tank to use to flush your toilet or water your grass.
Jan 21, 2015 | Comfort-Aire BHD-501 Dehumidifier
Our dehumidifier isn't draining into tank anymore and shuts off.
Daniele, the drain hole or drain hole tubing, that that flows thru to the bucket may be clogged. To loosen & remove the clog, do the following:
1. Turn the Master ON/OFF Switch to OFF & unplug the unit.
2. Remove the bucket from the unit.
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though).That's appropriately sized to fit into the hole or tube. Carefully insert the Zip Tie in to the drain hole or tube and continue to insert it until you reach a bend in the tube. You must gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly pull it back out while rotating (twisting) it, This will help dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
Completing the above, should dislodge any clogs and water will start draining back into the tank. Be sure that you have the humidity extraction level set on 35%, after you turn the unit back ON.
Jul 05, 2011 | Kenmore 54501 Dehumidifier
My Danby dehumidifier leaks out of the bottom. Water not draining into the tank but around the tank therefore out of the bottom between the tank and the dehumidier itself
Mar 23, 2011 | Danby Dehumidifiers
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over....
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Sep 28, 2009 | DeLonghi Dehumidifiers
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
De500p dehumidifier pump stopped working, help!!!
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
Jul 31, 2008 | DeLonghi DE500P Dehumidifier
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
70 people viewed this question
Top Winix Dehumidifiers Experts
Gil Shultz
ray gallant
Ken Wieczorek
Ken Wieczorek
Are you a Winix Dehumidifier Expert? Answer questions, earn points and help others
