Question about Kenmore 22422 Top Load Washer
How to remove the cabinet from a kenmore 90 series washing machin
I think i have a broken belt on my washing machine but cannot figure out how to remove the front cover.
    Problem Solver:
  • 14 Answers
Will have to change belt from back underneath.
Posted on Jan 03, 2009
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
How to replace lid switch kenmore 110 22922 washing machine
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet.
Then see the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=9b19162f839199d33f88dac696ac636c
May 07, 2010 | Kenmore Washing Machines
I have a Kenmore 70 series 28741
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82874120+
Go to the section on Top and Cabinet and you should see how the switch mounts to the cabinet.
You'll have to remove the cabinet first.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
After you've removed the cabinet, the rest should be relatively easy.
Sep 28, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer continully runs
Hello Friend, Your problem is easily solved. You need to replace the water inlet valve. It's easy to replace the water inlet valve on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you will be able to gain access to the water inlet valve. Simply remove the hose and wires from valve and replace with new one. Re-install the cabinet, control panel etc. This should solve your problem. Happy to help, Tim.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90
I need codes on kennmore elite calypso
Jan 12, 2008 | Kenmore 15864/15862 Top Load Washer
Belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
216 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
