Fault f-08
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: Indesit WIE167 washing machine, displaying F03,
Error code f03 relates to the thermistor on the heating element.
This can be a faulty thermistor or bad contact between it and the control board.
Worst case scenario is a fault with the board which would mean a replacement.
Hope this helps & thanks for using Fixya
SOURCE: washing machine fault
hi mine flashes when you are aloud to open the door so i cant see this as been part of you problem sorry cant help more
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
SOURCE: fault codes
Fault F07 indicates the heater relay is stuck, this could be due to a faulty heater, you need to test it to be sure, if heater o/k, then main pcb could be faulty.
Please rate my suggested solution.
Thanks.
