Question about Candy Washing Machines
Candy CDB-854 washer/dryer: Lights on, won't work
Hi, I've just had my new washing machine installed. The engineer installed it and put the machine on spin and it worked. He leaves, 60 minutes later I go to do my first wash and when I turn it to a program, half the lights turn on and stay on. However when I turn the dial or press the buttons, nothing alters the lights that are on, and no programme starts. The door remains unlocked too. No error code appears - the LEDs don't make any legible alphanumerics. Nothing is flashing, though the lights are lit above the Delay and Spin Selection buttons (but pressing them does nothing to the display). Does this sound like a fault? Will it reset itself by being off at the wall for a certain period of time? Many thanks, Lloyd
3 Suggested Answers
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
Candy CDB 854: Just installed, spin tested briefly. Now just lights and no function.
Turn the power back on, go through the instruction book to start the machine up. If its still not right, call the Service Agent. Its brand new and will be covered by warranty.
Apr 26, 2017 | Computers & Internet
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
Drum wont rotate at all
You mean it won't turn as in it is stuck? Or is it that the motor won't come on to turn it? Check door switch. Does dryer have power to it at all? Please rate my answer so I get points for it.
Jan 17, 2012 | Candy CNW136 Front Load Washer/Dryer
What do the symbols mean on my Candy washer and Dryer?
No manual supplied when new- or lost, I suspect?
Methinks you could do with one- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 21, 2011 | Candy CNW136 Front Load Washer/Dryer
I've used my machine twice this morning but now it clicks on to lock the door but the red light doesn't come on and machine doesn't start the cycle. Any ideas?
there is a problem either with the door lock or probably the 'door locked' sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Sep 04, 2011 | Candy CNW136 Front Load Washer/Dryer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
82 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
