Question about Panasonic Audio Players & Recorders
I bought a used subwoofer SB-HWA520 and i'm not able to make working paired with the bar
I have a system bar htb520 home theater, I have bought the subwoofer after. I have all the kit including the digital transmitter. It miss only the remote witch is back order. The problem is the the sub dont link with the bar. the led on the sub stay red not becoming green for indicating a contact audio.
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
sanjin
  • 56 Answers
SOURCE: subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Posted on Mar 10, 2008
SOURCE: subwoofer doesn't turn on
on mine...sub rumbles the whole house when i do the speaker test...but no other sound comes from it. same problem. see if it shows up in speaker test.
Posted on May 02, 2008
  • 10 Answers
SOURCE: Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Posted on Jan 19, 2009
SOURCE: Kube 2 subwoofer hum
The Kube Sub-woofer is earthed via its 3 pin plug. The Onkyo and other components I have in my system are not (they are double insulated). During normal operation, a difference in electrical potential can exist between these components in the system. I found that this potential was finding a path to earth via the audio cable and on through the subwoofer's earth. The path was via the earth portion of the audio cable and so gave the hum irrespective of volume levels set either on the Onkyo or the sub.
The fix is to ground the Onkyo to the sub. I used a length of electrical cable between a panel mounting screw on the back of the sub and a screw on the casing at the rear of the Onkyo. Try it out with a piece of cable manually touching screws with the bare ends of the cable until you find ones that give continuity( the hum will go immediately). I then crimped a small fork end electrical fitting onto each end of the cable which can be slid under the slighly loosened screw head and resecured. All I hear now is the fan on the Blu-Ray player!
Posted on Mar 12, 2009
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
How do i get my vizio soundabar out of retail mode without a remote?
Maybe the retailer who sold you the Vizio soundbar can tell you.
May 20, 2014 | Unknown Vizio SB4021M-A1 Home Theater...
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
How can I connect the subwoofer sb-wa920 to a any audio system
Some systems have a sub out. Does this sub have an output on it? If it does, use it first from your output then out to you other speakers. Hope this helps some but I could really use more information.
Jul 13, 2009 | Panasonic SC-HT920 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
79 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
