Question about Casio Fx-5800p Programmable Scientific Super-fx Plus Calculators
How to unlock mode fx-5800p ? - Casio Fx-5800p Programmable Scientific Super-fx Plus Calculators
Changing rad to degrees mode on fx82mu
fx-82MU?
If you mean fx-82AU, press SHIFT [SETUP] then 3, 4, or 5 to select the desired angular mode.
If you mean fx-82MS, press MODE then 1, 2, or 3 to select the desired angular mode.
Casio calculators almost always have the angular mode in either the MODE or SETUP menus.
Jul 23, 2014 | Casio Office Equipment & Supplies
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
WHAT IS ARGUMENT ERROE.?
Take for example a function y=f(x). What is inside the function is called its argument (what it is acting on). If you get that error it may mean that the argument type is wrong or that it is out of range. Here are two simple examples.
  1. A function requires a real number and you make it act on a complex number (wrong argument type).
  2. You know that the log () function must have a positive argument and you try to calculate say log(-2.5).
  3. Arc sine and arc cosine must have an argument in the closed interval [-1,1] but you call them with a value outside that interval.
  4. A function is defined with a list of arguments yet it is called with more items in the list or less items in the list.
Try displaying the values of the arguments before the function is called. This way you will see if you are passing it correct arguments.
Apr 09, 2013 | Casio Fx-5800p Programmable Scientific...
How to change the MATH mode to the default mode in fx-991es
MthIO is the default. Press SHIFT MODE 2 to select LineIO mode. All of the settings can be accessed through either MODE or SHIFT MODE.
Sep 16, 2010 | Casio FX-115ES Scientific Calculator
When i press the MODE button in my CASIO fx - 911ES
Just in case : Press [SHIFT][CLR] (9) [3: ALL] to reset the calculator and try [MODE] again.
If that does not work, your calculator may be defective or a fake (not the genuine article). If at all possible, return it to where you bought it and get a refund.
Here is a picture of the FX-115ES, its face looks like the 991ES. Hope I am mistaken.
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
I can only see 3 modes in my fx - 991ES. how can i unlock the rest of the modes?
Oct 17, 2009 | Casio FX-115ES Scientific Calculator
Convert to Binary in Casio fx-82ES
dear kladofora thire is no 4:BASE-N in the mode please i need help Gist
Nov 25, 2008 | Casio FX-300MS Calculator
It is actually about Casio fx-350MS
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=543801d4a05b81931455030518e0fa53&q=Casio+fx-300MS
Mar 08, 2008 | Casio FX-300MS Calculator
Casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
Feb 24, 2008 | Casio FX-300MS Calculator
Casio Fx-5800p Programmable Scientific Super-fx Plus Calculators Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
