Question about Canon BubbleJet i550 InkJet Printer
Is there something wrong with my Canon i550 printer head?
Canon i550 prints alternating light and dark horizontal lines when using black ink.
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Does not print black. ink tank indicates full and
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
Photo's print with lines through them
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Oct 25, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon i550 has has rainbow line in output
Even though you say you have ink, the "rainbow" line is usually an ink problem. Try doing a head clean process.
Right-mouse click on the printer and bring up "Properties". There should be a 'Maintenance" tab and one or more cleaning options and/or nozzle checks.
Sep 05, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550 doesn't print correctly
---Is the incrustation of the heads or the ducts such that I need to throw the i550 away
This one...
I had 3 Canon i550 and i560 printer, unfortunately if you use non original inks and leave the print head with no ink cartridge for some hours the ink can dry inside the print head = dead.
I have try several methods of cleaning print head and waste a lot of time on this, finally here some suggestions:
- use pure alchool (at least 90 °) to clean the print head, you can also use clear water but after you had to rinse with alchool because alchool removes the left water that can cause shortcircuit when you power on the print head.
- the electrical connections of the print head (brown ribbon with integrated circuit path) are very fragile if you decide to unmount the print head removing the 2 phlilips screws you must be VERY careful
- for black ,one safe trick is to remove the round (8 mm) glued upper metal sheet filter on the upper part of the print head where the ink cartridge sets. Once removed you can use a syringe needle filled with alchool to remove the dry ink and spray alchool into the small duct hole to remove all the bad dry ink. Be patien it will take some time. You can also leave the syringe filled wyth alchool and without the syringe piston for a night inside the duct hole.
Take a look to the service manual also for other inspirations:
http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
Nov 11, 2007 | Canon BubbleJet i550 InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
162 people viewed this question
old marine
old marine
