Question about GE DVLR223 Dryers
GE dryer barely heating
My GE DVLR223ET1WW electric dryer takes a long time to dry my clothes. I checked the voltage at the receptacle and I was getting 120VAC, is it supposed to be 240VAC? The voltage at the end of the power cord to the dryer is 120VAC at L1, 0V at L2 and 0V at the ground wire. From what I've read L2 is also supposed to be 120VAC, but that's only possible if I'm getting 220VAC from the receptacle. Please help!
  • Elisha Tigah Jan 06, 2009
    I'm only getting 120VAC at the receptacle and all other receptacles around that area. how to I change it to 220-240VAC? the dryer heats, it just takes too much time to dry. thanks for your help.
  • Elisha Tigah Jan 07, 2009
    I managed to find a 22-240VAC outlet. but when I connect it to the dryer, I get absolutely no heat although the dryer tumbles. I measured L1 and L2 on the dryer side and I get 122V each totaling 244VAC, so the power cord seems to be fine.
    However, when the dryer its connected to 120VAC, I get some heat but not much to dry clothes in one cycle. what could be the problem?
  • 5,911 Answers
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Posted on Jan 03, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 07, 2009
    If this is an ELECTRIC dryer, you need a dedicated 220-240VAC outlet for it to operate correctly. The heating circuits and timer in an electric dryer require 220VAC to operate, while the motor uses a tap off of this source voltage and operates on 110VAC. If you are getting 220VAC at the outlet and the dryer tumbles, but you still do not have heat, you more than likely have a problem with the heating circuits. The following link explains:
    http://www.fixya.com/support/r630242-dry...
    I do not understand why you're attempting to run a dryer on 110VAC. Maybe I'm misunderstanding what you're trying to explain to me. Your dryer will not operate on 110-120VAC service. In any case, please read through the link and let me know if this helps.
    For some helpful diagrams to assist you in identifying components on your dryer, go to searspartsdirect.com and type in the model number you provided. The heating circuits are listed under the "Drum, Heater Asm, Blower and Drive Assembly" heading. The thermostats are listed as items 505 thru 507. The heating element is listed as item 512. I would first recommend you check the safety thermostat (item 505) for continuity. It should read a short (0 ohms) if good. Most dryer heat related problems are attributed to poor ventilation, which leads to an overheating of the heating circuits. This usually results in the safety thermostat blowing. I would also recommend you check the heating element as well. The element should read a low resistance of about 15 ohms or less if good.
    I hope this helps you. If you still require assistance, please let me know.
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
My electric amana dryer heats up but does not seem to blow the heat around and the lint is only gathering at the bottom of the lint trap, so it takes forever to dry my clothes. What do I need to do?
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Amana ALE230RAW Electric Dryer
Dryer not drying clothing.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer screeching noise GE - DVLR223ET1WW
Remove the back panel and check the brake to make sure that it is not staying locked to the drum.
Jun 01, 2009 | GE DVLR223 Dryers
GE dryer will not dry towels
How warm is "warm"? If the clothes are warm to hot after 15 minutes of running but not gettign dry, you do not have a heating element problem. Sounds like you still have an air flow problem. Does the heating element cycle often? You may have lint clogged at he entrance to the blower. This would be out of sight from the exhaust. Try removing the exhuast hose and running it in air-only and feel the amount of air leaving. It should feel like a lot of air coming out. If not, you will need to check the condition of the blower. I had this same issue and ended up pulling the blower cover off and pulled out a very large amount of lint..it was almost completely clogged. Afterwards it drys really fast! Good-Luck.
PS If you do not feel comfortable accessing the blower, you should have a professional do it for you.
Mar 23, 2009 | GE DVLR223 Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
GE DVLR223 Dryers Logo
326 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
