Question about Creative Labs ZEN Vision:M Digital Media Player
Will not select from main menu
When I switch on it comes very quickly to main menu rather than going through the normal start up procedure, also will not update after docking. When i try and select from the main menu, say music library it will not respond. I can however select album of the day via top left button, if i then try and use the central button it seems to try and work but immediately stops again. Volume and back/forward on that button are fine. Thanks anyone who can help me not have to replace.  If i do need to replace any suggestions, i need to use with Napster to go and want 30GB +. Thanks,
john
  • 45 Answers
Just press the reset button in the back side of ur player
Thank U
Posted on Jan 05, 2009
I have a Nikon d3300 that turns off automatically after i take a photo - can you assist
If the screen display is shutting off, that's a normal function. If the camera is entirely shutting off it might be a bad battery or a very weak battery.
Sep 28, 2016 | Nikon Cameras
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c 450 error c 3752
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure: 1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Apr 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
MY samsung GT S3850 is restarting again and again once i switched the phone on
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Oct 24, 2012 | Cell Phones
What is emergency calls
YES you can unlock it yourself but unfortunately you will have to reset it and lose all your apps/pics etc.
1. switch off. Hold volume UP and power button and home button simultaneously. release home button (and press again) while still holding volume up and power button. A boot up screen will pop up. Use volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked. Get another phone to call your phone. as soon as you swipe answer press back key (arrow key) (you gotta be quick) and the main home screen will come up!!! . press the left menu button and select settings and turn off pattern code then go to menu and factory reset the phone again.
It worked for me ,.. hope it works for you too
Apr 17, 2012 | Samsung Galaxy Y
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Bizhub c450 error c3752 Guillemin
Reset Procedure:
starts.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Konica Minolta bizhub C450P Laser Printer
Not sure how to save during game play on pippa funnell 2 nintendo
Is there an options menu on the game? The save button is usually in there.
Jan 10, 2009 | Nintendo DS Lite Console
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
