Question about Epson Office Equipment & Supplies
Automatic document feeder error epson workforce 635
Automatic Document Feeder error message won't go away
2 Suggested Answers
Icebassman 5
  • 57 Answers
SOURCE: epson workforce 600 error message; please clear document feeder
Hi there.
Still there might be traces of dust or small paperpiece somewhere.
Iceman.
Posted on Nov 10, 2009
WOT DOES ADF MEAN ON MY EPSON WF-2630
ADF stands for Automatic Document Feeder - used for scanning multipe paper feeding
Apr 15, 2016 | Epson WorkForce WF 2630 Wireless Printer
How do I fix the automatic document feeder on my Epson wf-2530
The best way to sort this out is to First go to the Epson website (http://www.epson.com) and click on your location - many Epson printers have different model numbers and drivers depending on location - then download the drivers and other software for your product - the website will normally correctly identify your operating system so you get the right products to download. Before installing do this - go to Start - Control Panel - Printers then click on the printer icon and press the Delete key on your keyboard and thus delete the existing installation. Obviously you should have the printer switched off for this operation. Now run the setup for the new download and when advised onscreen, switch on the printer and when all finished, your printer and its facilities should all be properly restored. Sometimes problems such as yours can occur through another background utility interfering and rendering something inoperative or could have been a small electrical spike. In any event, do the reinstall using latest software as described.
Aug 22, 2014 | Epson WorkForce WF-2530
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Epson workforce 600 error message; please clear document feeder
Hi there.
Iceman.
Nov 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
Dell 1600n laser printer has error message of document jam
the automatic document feeder has a few sensors on it, most likely one of these has become displaced, ofter they are just clipped in so if you are handy with a screwdriver lift the lid and remove some screws from the bottom of the document feeder and gently dissasemble, not expert at this model but take it slowly or get someone handy to do it, once youve got to the circuit board in the automatic document feeder the problem will be one of the arms that breaks the beam in the optical sensor (black U shape) should just clip back in and problem solved.
Sep 25, 2009 | Dell 1600n All-In-One Laser Printer
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
