SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
SOURCE: Cleaning the heads on a Epson Photo R300
the heads are removable if you remove the back plastic cartridge holder first with pointed pliers then there are two screws at base accessable with printer intackted. you only have to set the carrage to cartridge change position to do this. once removed use a rubber tube on a cyringe filled with water and blow jets through several times and replace as removed....
