Back to:
Tags:
Fuji FinePix A345 Digital Camera
Fuji A345 finepix
posted by khachkhach on May 16, 2007
i am having a persistant problem with my digicam in terms of battery.Ive tried changing 'n' number of batteries,both AA-duracell as well as Ni-Mh batteries but still after 30 pics it show the red indicator for low battery..
is there any problem with camera's battery points or any other technical fault in the camera .please advice me so that ic an take appropriate action.need help urgently!!!
karthik
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 16, 2007
Not Rated (0)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3707 votes
As batteries are recharged- they develop a 'memory' That is to say starting with a new fully charged battery- the 'low' light may come in when the voltage drops below a certain value.
The battery is not however fully discharged.
It could have say 25% residual in it.
When recharging- the charger is charging the 75% only, and on the next recharge- that mush less again until the battery is only offering a small percentage of its capacity.
The answer is to put the low battery in a simple device - a torch - until it is completely down
Then recharge - you will then get the full capacity of the battery.
Meanwhile do contact the Tech support of the manufacturer just in case there is a known problem with a given model.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fuji A345 finepix:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
My son dropped the camera, probably from a couple of feet,...
on power up the display is blurred and if a photo is taken...
The screen is will go white after taking a couple...
The image is blurred and will not focus.
when i turn on my camera it is stuck on the...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
