Question about Gateway Computers & Internet
Gateway laptop power button
Nv79 power switch
  • mark54568
    mark54568 Oct 30, 2012
    I think I need to replace the power switch. I dropped the laptop on the switch and the silver plastic barrel shapped casing that surrounds the switch is cracked.
  • Gateway Master
  • 15,557 Answers
5 Suggested Answers
  • 7 Answers
SOURCE: someone locked the touchpad Mouse on my Gateway
Hi i have researched this as i didnt know personally people have told me it s different for certain models and the 3 main options i have seen is this
Option 1: Press FN+F5
Option 2: Press FN+F7
Option 3: *Requires a USB mouse for temporary use* Follow Link http://support.gateway.com/s/Mobile/SHARED/FAQs/1008796faq29.shtml
I really hope this helps as i would be lost if i couldnt use my laptop or my pc
Goodluck
Carl Redding
Posted on Jul 18, 2010
  • 22 Answers
SOURCE: i just started my laptop the other day and my
Hi Leslie,
You can try this first: http://en.kioskea.net/faq/1902-disable-enable-the-touchpad If still can't, check whether your hardware is detected and installed from Control Panel -> System -> Hardware -> Device Manager and look for the touchpad device status. If everything is fine, it might be an hardware issue.
Posted on Jul 30, 2010
KHANtheGR8
  • 277 Answers
SOURCE: Power issues with gateway nv79
check the power supply(adopter)
Posted on Sep 12, 2010
  • 182 Answers
SOURCE: i need instructions to replace a keyboard for a
Hey, for that i guess you must have already bought new keyboard and must have Philip screwdriver handly
remove the power source battery and ac adapter then remove the hinge cover from the back of the laptop, remove the top from pate from the top of the keyboard and unscrew the keyboard(there would be two screws on top let and right)
Take out the old keyboard and replace it with the new keyboard and screw it up and put in the plate and hinge cover
Also i would suggest you to watch the following video, though it is for Dell however it would be really hepful for you to perform the action with your Gateway Laptop
http://www.youtube.com/watch?v=9x5SF_NFsw4
Posted on Sep 17, 2010
My gateway nv79 laptop no longer shows it having a web cam where did it go. if I try to install drivers it says I don't have a webcam
Are you sure of the driver? Go to the gateway web site and download the correct driver. If that doesn't work, look for a new web cam.
Sep 25, 2014 | Gateway NV79C48u Laptop
Can the cpu be upgraded on a Gateway NV7915U Laptop?
The Gateway NV7915U Notebook PC, is one of the Gateway NV79 series, of Notebook PC',
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/NV79/NV79nv.shtml
Click on Specifications
( Or http://support.gateway.com/s/notebook/2009/gateway/nv/NV79/NV79sp2.shtml )
Look to the right of - Processor
These are the Intel Core processors that are supported by your laptop.
Further; look at the motherboard chipset used,
Intel Mobile HM55 Express chipset.
More information on the Intel (Mobile) HM55 Express chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_i_Series_mobile_chipsets
Look under the first heading - Chipset - at HM55
Read across, and match up to the headings above.
This information supports processors, that Gateway Support has listed above.
Regards,
joecoolvette
Nov 02, 2011 | Gateway NV7915u Notebook
How to turn on cam in gateway nv79
how to turn on my gateway NV79 webcam
Oct 20, 2011 | Computers & Internet
No driver for wireless on my gateway loptop model NV79
Below are links to three versions of the driver for the NV79's wireless LAN. Which is the correct one will depend on the manufacturer of your notebook's on-board wireless card. For simplicity sake, I recommend just downloading and installing all three; your computer will be able to determine which is the correct one.
Here are the links:
Intel: Download
Atheros: Download
Realtek: Download
Each of these links was obtained from Gateway's official driver download web site for the NV79 Series notebook computer (which you can access here).
If you found this solution helpful, please leave a positive rating!
Sep 07, 2011 | Gateway NV7915u Notebook
Power issues with gateway nv79 laptop
Sep 12, 2010 | Computers & Internet
I have a gateway nv79 laptop and it will not power up. The power light and the battery light stay lit red for a few seconds then the power light only stays light blue for a couple of seconds. It simply...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 12, 2010 | Gateway Computers & Internet
Touchpad doesn't respond
Go to this Gateway Webpage and Do any/all Updates related to you system.
http://support.gateway.com/support/drivers/search.asp?st=pn&param=NV79
Jul 08, 2010 | Gateway NV7915u Notebook
I have a new gateway NV79 and the mouse pad is locked
There is a touch pad toggel button on the top of the keyboard press it and turn the light off , touch padd will work icon_touchpad.png Touchpad toggle Turns the touchpad on and off.
Jul 02, 2010 | Gateway NV7921u (LXWHH02010) PC Notebook
Computers & Internet Logo
187 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
